77turbocarrera's Avatar
Throttle shaft bushings
Anyone know the location of all three of these plastic bushings? I found the 2 by the shifter and the parking brake, can't seem to find the 3rd one.
Old 11-30-2016, 07:42 PM
full quack's Avatar
Send a message via Yahoo to full quack
There is the linkage arrangement right off the trans on the drivers side, takes 2 bushings there.
Then there is the linkage arrangement on the top of the engine near the triangle of death, takes 2 there as well.
Mark
Old 12-01-2016, 06:07 AM
Mark
Just to be sure, I'm referring to #13 on the schematic. It shows 3 rubber bushings. It looks like there should be one near the gas pedal, but I don't see anything that would hold a bushing.
Old 12-01-2016, 02:27 PM
Is it possible these are the two you have found and one more near the rear bulkhead where the cable exits the pan? Not sure as I have not pulled my throttle cable before, but the schematic looks that way to me.
Emery
1988 930 coupe - Silver Metallic
3.3L w/GT35R, B&B Headers, RarlyL8 muffler, TurboKraft IC, Tial WG, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 12-01-2016, 02:45 PM
full quack's Avatar
Looking at the exploded view, it looks like #13's are the rubber grommets for sealing/supporting the throttle cable as it passes alone the pan tunnel. The #12 is the dust/water boot where the cable exits the pan, right above the torsion bar housing tube in the rear.
The pivot shaft bushings for the gas pedal assembly are #28 at the pedal assembly drawing.
The lowest drawing is from the transfer position at the tranny on the drivers side.
Mark
Old 12-01-2016, 03:05 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
