Turbofrog
smurfbus's Avatar
TPS and TB for pancake manifold?
My stock tb is somewhat machined where the TPS adapter is normally bolted (upper bolt hole machined of) and there is a plug at the axle end. Is there a adapter for the shaft to tps connection available?
Or
Is there a easy upgrade tb available if the pancake itself is not a bigger bottleneck with 40 mm outlets.
79 930: HX40S#16, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, True split BB, 2*turbosmart38
Old 12-29-2016, 12:39 PM
Slippery slope skier
Costa P's Avatar
Hi smurfbus,
There is a nice TPS kit from TK. It includes a replacement TB shaft and adaptor plate for the TPS.
There are some nice close up shots in the videos filmed by "speed academy", while TK was building his motor.
TurboKraft Full Engine rebuild, EFI, + more - Build Thread
Cheers
Costa P
'85 930 Grand Prix White ...the oil leak rebuild which mutated into MoTeC EFI+twinscroll GT35R+twinplug+ ...
930 rebuild The revival of my mothballed project
Old 12-29-2016, 11:31 PM
Turbofrog
smurfbus's Avatar
Saw that but I already have a sensor and flange for it. I might have to buy that tk kit anyway as its clever and looks like comes with longer rod too.
Old 12-29-2016, 11:39 PM
Turbofrog
smurfbus's Avatar
Old 12-29-2016, 11:40 PM
Turbofrog
smurfbus's Avatar
How should I remove the plug? Drill straight or punch through from the other side after removing the rod by pulling? I dont want to do permanent damage to the TB.
EDIT: It popped out with a small whack on cable side end. Now its obvious I need a longer butterfly rod. Even with no nut on the other end it would not reach the sensor.
So if there are no upgrade throttle bodys available for pancake manifold I need to mod/lenghten the rod or buy the TK kit.
Old 12-31-2016, 02:15 AM
Costa P's Avatar
I have a brand new TPS kit from TK (including longer shaft etc), I don't mind taking some photos if that would be helpful to you.
I bought it but then decided to convert to drive by wire and ended up replacing the whole TB!
Costa P
Old 12-31-2016, 09:09 AM
Turbofrog
smurfbus's Avatar
I drilled and tapped the short rod so I can use 4m bolt for extension. Just need to find the correct angle for tps lock up and grind the bolt end so its tight against tps. Which tb did you go for?
Old 01-01-2017, 02:16 AM
Costa P's Avatar
My mechanic offered me a good used one from 996 turbo, from another client that upgraded to a larger TB.
A google search on the Porsche part# indicates that this TB is used on various P car models.
You need to either modify the TB or make an adaptor plate to mount it to the pancake manifold. The position of the 4x mounting studs is similar but not a direct fit.
Old 01-02-2017, 11:20 AM
Costa P's Avatar
With regards to the TPS kit from TK for the 930 TB:
Costa P
Old 01-02-2017, 11:29 AM
Turbofrog
smurfbus's Avatar
Thanks. It seems my tps kit missed the longer rod and its on its way now.
So now you have also some throttle potentiometer on the pedal assembly or did you use the cable for throttle sensor measuring?
Old 01-03-2017, 03:44 AM
Costa P's Avatar
My plan is to install the e-throttle potentiometer at the end of the throttle cable (on top of the engine). I don't want to make changes to the throttle pedal itself.
Costa P
Old 01-03-2017, 08:23 PM
