-   -   MS3X & MS3Pro - Tacho calibration (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/942385-ms3x-ms3pro-tacho-calibration.html)
dap930 01-14-2017 09:23 AM
For people using MS3/MS3X and MS3Pro for EFI, you can calibrate your tachometer to read what Tuner Studio shows for your actual engine RPM's. I my case, my tachometer was reading a little high, so I adjusted it using the Tacho drop down menu:
http://forums.pelicanparts.com/uploa...1484414181.png
Note that you will need to do a power reset once you select "variable". Then you can select a percentage that bring your tachometer in line with what TS is reporting for engine speed. I noted tachometer readings at various engine speeds rechecked the car tachometer after adjusting the tacho %.
boosted79 01-14-2017 10:38 AM
Does that mean your tach was reading 14% high? So when it was saying 6000 rpm, the actual was 5263?? 5263 x 1.14 = 6000. If so, that's huge, or is the 86% just hypothetical?
Tippy 01-14-2017 11:03 AM
I need to adjust mine too
dap930 01-14-2017 11:40 AM
My tachometer was rebuilt several years ago when it quit working. Ever since, it seemed that read a little high and it seemed a little over damped. Since converting to EFI, I have always noticed that it read higher than what Tuner Studio reported. I just recently saw a post in the Megasquirt forums where someone said that the tacho output could be used to adjust the car tachometer output. I had not been aware of this. In my case the car tachometer would read close to 1200 RPM's when TS indicated 950-1000 RPM's. I did check at 2K, 3K, 4K and 5K and the tach did track closely with RPM's TS showed. As far as the tach being 14% off, it did not seem to respond in linear manner with 1% changes in TS. I guess I could look at the tacho signal with an o-scope to see the difference between 100% and 86% settings.
db9146 04-08-2018 07:56 PM
Dennis,
What output on the MS3 are you using? Pin 25 (IAC1A) or something else?
Dee
jpnovak 04-08-2018 08:52 PM
Yes, all my factory tachs read higher than actual measured rpms.
billjam 04-09-2018 06:10 AM
I have noticed the same issue with my tach. It reads significantly higher than what I see in TunerStudio, however I don't understand how an adjustment in TS will render my tach reading correct once TS is disconnected. Am I missing something here?
Dennis, I can't find that Tacho Output window anywhere in TS (v3.0.28).
PS, my car is running great now.
GJF 04-09-2018 06:25 AM
The signal is sent from the ECU not Tuner Studio. Once the value is edited to the ECU using Tuner Studio, it doesn’t matter if the Laptop is connected the edited value in the ECU is what your tach will display.
Tippy 04-09-2018 06:32 AM
My tach is opposite. It lags TS.
For some reason, once it hits about 5K, it slows down and never actually reaches peak RPM that TS shows.
Never minded it much, honestly.
billjam 04-09-2018 07:02 AM
Ah yes, that makes sense. Still can't find that Tach Output window though. :confused:
billjam 04-09-2018 07:20 AM
Found it ... but it doesn't have the same options in my TS.
http://forums.pelicanparts.com/uploa...1523283627.jpg
Tippy 04-09-2018 08:29 AM
You have the latest TS?
dap930 04-09-2018 03:38 PM
Bill,
I have V3.0.28 for TS. Do you have the paid version? It should auto update.
billjam 04-09-2018 04:08 PM
Dennis, I have V3.0.28 and it is the paid version which auto updates.
I just looked at the Help menu in TS and there is an item called "Upgrade for even more features" to a version called MS Ultra.
This may be what you have, so the extra MS Ultra functions might include the tach adjustment. It is a $40 upgrade.
dos531 04-09-2018 04:41 PM
It's not the version of tunerstudio, it's probably the firmware on your megasquirt. Have you updated that recently?
dap930 04-10-2018 08:47 AM
Bill,
dos531 is right, the Tacho adjustment feature was available on V1.4.1 firmware because that was the version I had when I made adjustments to my tach. Of course V1.5.1 is now the latest, but it implements engine states which requires a little work to fill in the engine state parameters.
