LinkBack | Thread Tools | Rate Thread |
Chain fence eating turbo
X-post - Heads are lifting at 1.4 bar of boost. What to do now? (Photos)
Eating crow right now, as I thought lifting heads was a figment of ones imagination.
![]() ![]() Appears my heads are lifting from 1.4 bar of boost. Did not see this at 1.2 bar on 1st rebuild. Been reading that flame rings aren't a guarantee?? If flame rings aren't a cure, what is? Also, what is happening around the piston crowns? ![]() ![]() ![]() ![]() ![]()
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel Last edited by Tippy; 01-19-2017 at 05:56 AM.. |
WOW, tippy! That's some serious boost'n. What compression are you running? Any potential the oil residual build up would cause compression to be higher than expected? Are you using a oil/air separator from crank case pressures and or recirculating back to intake? Curious where the build up is coming from.
- '88 911 (3.6 Transplant, Big Reds, Coilovers, & Headers) - '12 Audi B8 S4 (6MT) - SOLD! '84 911 3.2 Turbo Targa - SOLD! '85 928S 5sp with LSD |
We can see that you have the good 993 dilivar head studs. What did you torque them to before?
I've been told by a top Porsche engine builder you can torque those to 36 ft lbs in race motors and they won't break. I've never tried that with dilivar head studs but if you don't want to buy new ARP, Supertech, or Raceware head studs and torque them to 38ft lbs for ARP or whatever the others are supposed to be if they are used then I would try those 993 studs at 36 ft lbs with thread lubricant on the studs, nuts, and washer contact surfaces. Good luck with it ![]() |
FWIW, I used the stock 930 oil/air separator and it was quite effective. May help with the excess oil ingestion, coating on pistons, and hemisphere area.
Tucked in on the right side, behind BOV. Hose leading from filler neck ![]() Part #9 ![]()
Turbo Powered Snow Blower
That is diesel engine cylinder pressure, almost 18:1, and the older 7.3L engines had head bounce issues when boosted to that level. As mentioned you need better studs that will resist the stretch. Can these engines be o-ring'd? I would think ARP 2000 studs and O-rings would hold up. If not you need to back down the boost.
Question. At what level to the stock rods and crankshaft become an issue with these engines?
Derrick Last edited by 1979-930; 01-19-2017 at 07:44 AM.. |
Some given torque, then angle. I did this dry, and remember they creaked a lot during torqueing. Sounded like they wanted to break any second! I felt torque was well over 36ft/lbs!! |
Use some type of thread lube on them, or a drop or two of motor oil before tightening them.
First off, head studs are not the problem. To expect the heads to seal at 1.4b manifold pressure without any sort of sealing system is your problem. Running pressures are more in the 200 -300b region. Thats what you are trying to seal.
Sure a better head stud will be better but it wont solve the problem. It will empty your wallet though. Better spent on a good sealing system. Call Performance Developments. They developed one years ago many have copied. Multi piece system that does work. As for your question regarding the Pistons, best to look at the plugs. They will tell you what is going on inside the cylinder better than anything else. |
It's a 914 ...
It's a 914 ...
Found this from their web site Parts – performancedevelopments.com
"Sealing System – Head Gaskets multi ring sealing system for all 911, 930 and 993 engines. The dual ring system for the 996 and 997 Turbo engines use our proprietary Back up Ring along with custom Head Gaskets made especially for this system. A gas filled Garlock Ring is used to seal the Cylinder gases" I wonder what that would look like on a 3.2 head. |
It's a 914 ...
It's make for V8 cars. I modified it. |
Crazy stuff
How about an aviation-style threaded cylinder-to-head. I believe Capricorn/Perfectbore once made that.
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Ni-resist were stainless rings to stop the combustion from burning its way out. They floated in a groove. Didn't seal the gas pressure very well.
These are special Be Cu rings (multi) that are under different levels of crush. Best to call PD and get the full scope. I remember they did lots of them back in the day. |
What made you pull it apart?
3.3 ltr, stock compression, efi, twin turbo - no intercooler. |
Clutch started slipping. Then, I had oil leaks after about 100 miles after I rebuilt it the 1st time.
Figured, if I have it out, might as well reseal it. Slid right off the slope.... |
Thread Tools | |
Rate This Thread | |
