Help with wiring 930 Relays on a transplant
I am working on cleaning up the wiring in my 1972t with a 1986 930 motor in it and I need help with the right wiring fir the relay panel/fuel relays. Does anyone have pictures abc or or diagrams to help? Here's what I have to deal with
The rear relay I'm removing since it's for the rear defogger, the other two I need to see how to wire them, most wires are cut??
Better view of the wiring on the relays, I also need to figure out how to put th overboost sensor back in the loop for the fuel pump
Is this the correct wiring points for the relays?
I noticed there aren't any fuel pumps on your schematic. ?
Steve 86 930 91 535i 73 TR6 |
The other schematics I'm using
And this one too
Great, thanks. PO by passed relay G in my car. I'm gonna put it back as my pumps run all the time when the ignition is on.
put heat shrink on those bare soldered wires,
I would also solder any crimped wires, I use the bare connectors with a little solder then heat shrink over the connector,
86 930 42kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 05 BMW 330CI 130K:: [_ ![]() 08 VOLVO V70 190K:: [_ ![]() 90 B2200[__] RUNNING:[ ![]() ![]() |
I'm redoing all the connections with solder and heat shrink, and trying to get rid of any wires no longer needed.
Does anyone have a hi-res of this image? Or PDF? ![]() |
I would like a copy of that image too. I'm building my data base for when I rewire the car. That will not be an enjoyable task.
James 1989 Slate Grey 930...sold ![]() |
Thread Tools | |
Rate This Thread | |
