I think the Chinese ones are URO brand. If the Porsche dealer relays are from the same supplier and it's possible more than one place is making them there and some are better than others, the lowest bidder.. etc.
The ones you buy from Porsche will hopefully have gone through their own final inspections and put in a cool little box. |
Crotchety Old Bastard
I bought both types and they appear identical. Both embossed Made in China. The only difference is the "OEM Supplier" brand cost $19 and the "Porsche" brand cost $34. The one that failed in my car was the Porsche brand unit. I believe this is where the term "Porsche Tax" comes from. I can understand higher prices for low volume products, I experience that with my line of exhaust systems, but to charge double just because it's put in a fancy box and sold to wealthier folks is deceptive and complete BS.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Metal Guru
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Mighty Meatlocker Turbo
I think one of the things that most floored me when I first bought my 1987 back in 2006 or so (had never even ridden in any kind of 911 prior, or even looked one over very closely) was how similar many parts of the car were to the two 1971 914s that I owned in the past - plywood floor boards ![]() ![]() ![]() ![]() And then I started to learn about the pre-Jurassic fuel system still being used, when much better options had existed for years, and was like a triple ![]() ![]() ![]() Last edited by Rawknees'Turbo; 02-09-2017 at 11:19 PM.. |
I had a similar experience, my first 911 was a '73T MFI. Next was a '78SC. I compared that '78SC to my brothers '78 Pontiac Trans AM and was just puzzled at how primitive the 911 seemed. It was simple though and easy to work on. Forward to the '85 930 and nothing much changed. The 928 was a space shuttle compared to the 930. Then they kept the basic CIS 930 air cooled engine until 1994??? WOW, talk about a cash cow! Still there is no excuse for these relay and fuse issues to not be addressed for over 20 years of production. Now that there are no quality parts available this becomes a real issue.
Work in Progress
Brian,
I recall you doing a little write-up on installing the fuel pressure gauge. I searched but couldn't find it, any chance you remember where you wrote that? Thanks Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Follow up to the story, the car has been sitting sense the relay was changed out as I haven't had a chance to take 'er out for a romp. Took some time today to do that and verify everything is OK.
Well it's not exactly OK and again the gages tell the tale. Car fired right up and the AFR's and fuel pressure rose as they should over time as the engine warmed. Typically I just get it and go but this time I wanted to observe the entire warm-up cycle. Once the fuel pressure reached 53psi the AFR is usually 13.0:1, this time it was 12.5:1. That's odd. So I got out the little allen wrench and cranked the idle mixture screw until the AFR raised to 13.0:1. At that point I heard a slight miss and random pop out the tailpipe. It sounded like a lean pop. After thinking about this for a second I realized it was a lean pop and lowered it back to 12.5:1. I'm pretty sure what has happened is the plugs have fouled causing a slight miss and rich reading due to incomplete burn. I went ahead and took 'er out for a drive, sounded really good off idle but I could hear a slight miss at even cruise. AFR had dropped from typical 14.3 to 13.7. Got to a good spot and stomped it to blow all that leftover carbon and fuel out and WOW, what huge plume of smoke blew out when the boost hit! Repeated again and the smoke was gone. Took 'er home and at idle there was a distinct miss. Looks like new spark plugs are in 'er future. Not really unexpected, could have been worse. So one more thing the AFR gage can tell you, fouled plugs!
I don't really have much of a clue about this, I let Tuner Studio calculate it. Am I so far off base? ![]() |
CIS does not offer infinitely adjustable tuning of idle vs cruise. Idle runs nicely at 13.0-13.5 AFR and cruise 14.2-14.7 AFR. The adjustments are not independent, you can plan on about a 1.0 point increase from idle to cruise.
'87 slant conversion I bought last year has no relays, red covered aircraft toggle next to the key. Flip it on, pumps start, turn the key. Flip it off, engine shuts off. No air meter switch, don't get in a wreck.
On a more practical note, Summit and various other places have inertia switches, I'd put a relay in and use the manual switch to power the relays and put the inertia switch in line with it to interrupt the power to the fuel pump relay in the event of a bump. I put one in the plane after Kyle and Amanda Franklin's accident a few years ago (survivable crash, she died because the smoke oil pump kept on pumping). Easy to install, place it in the the circuit between the power supply and pin 86 (I think, power supply to the coil). Hard to trip accidentally (rough road won't do it for example) but any crash would certainly do it. |
That's a great idea with the inertia switch. I don't like driving it with this setup and am going to re-engineer the whole circuit with good relays, not these Porsche ones. But that is in the future along with EFI. Worst case scenario with this setup is you get in a wreck, engines stalls and you can't flip off the pumps, fuel line is broken, pumps keep pumping and it's crispy critter time.
This is actually the one I use. When you say "aircraft switch" is if the Carling G series? Or the Potter Brumfield switches with the built in circuit breaker? The right switch spec should handle 30A without problem, but the PB switch breakers have gotten a bit of a rep for failing in the field due to internal mechanical issues with the woven copper "wire" that flexes when you actuate the switch. I like the Carling G series personally, have switched everything to that. Last edited by flightlead404; 02-12-2017 at 08:40 PM.. |
Bucketlist
Steve 1981 SC Steel Widebody, DP Lid, 930/51 to 3.2l, K27 7006 Turbo, DOD, P&P Twin Plug heads, Twinfire Ignition, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, 044 pump, BLwur, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters 2003 BMW Z4 Daily Driver & Autocross car. Sold |
I'm not sure what make it is, I haven't taken it out. It's just a metal toggle with the red flip up safety cover. The guy who sold it to me is a pilot and he restores vintage biplanes. He does beautiful work, he used the factory slant fenders and headlight mechanism when he did the conversion on this car. But he also trades natural gas futures and I suspect he may have got in over his head, thus my purchase of the car. Good info on the Carling switches. If it's good enough for an aircraft, it's more than good enough for a car.
Thread Tools | |
Rate This Thread | |
