Hobbs makes adjustable pressure switches, but they are 1/8NPT not M10x1.0mm -- similar enough to thread in, different enough to damage threads of the housing.
I am hooking up my HKS unit and snapped this picture as it shows another reason why I prefer a high quality unit. Simply, the mode of failure.
https://c1.staticflickr.com/4/3820/3...0f43074f_c.jpgIMG_4012.jpg by Shannon, on Flickr The HKS unit uses a separate boost sensor, if a overboost is detected it will warn and/or drop the boost down to separate pre-set. I believe also that the higher quality solenoids fail 'open' as a matter of principle. |
Biggest risk is a 20 cent vacuum hose. That was an expensive lesson.
True. The original fabric covered rubber vacuum lines eventually get brittle and crack easily if moved. The fabric covers the cracks that become vacuum leaks and you can't see the damage.
mine was the angled one on the boost conrtoller valve. It split at the track that was why i got that set of pistons and cyliders from you.
Call me an idiot or wuss, but I actually turn it down to minimum at the track (.3bar) until I can reasonably drive the car 'fast' at that level. So far it's been plenty fast for me. I turn it up on the street for occasional fun moments. |
| All times are GMT -8. The time now is 11:39 PM. |
