Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Getting ready to drop $20,000 on engine overhaul
Originally Posted by Rich76_911s View Post
Has anyone done a compression or leak down test on this engine?
Does it burn excessive oil?
I just rebuilt my engine over the last year. I had a broken head stud causing a high leak down on the #6 cylinder that initiated the rebuild.
If it comes to rebuilding the engine Contact Chris at TurboKraft about supplying bearings for your engine. I believe he's using Porsche Motorsports gt3 main bearings and clevite rod bearings with coatings. Also make sure to use the better gasket kit by wrightwood racing.
You seem hot to trot on rebuilding an engine that doesn't sound like it needs a rebuild.
Good luck.
No smoke and.. don't drive it enough to know if Im burning oil.
I'm only looking to have the rockers/valves/guides done. But we will see if this is a option.
What did it cost you?
Old 03-19-2017, 07:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #141 (permalink)
I've always lived by the words, don't fix what isn't broke. Put some miles on her this summer and take it from there.
Old 03-19-2017, 07:53 PM
  Pelican Parts Technical Article Directory    Reply With Quote #142 (permalink)
Last thing I'll say about this until hear from the shop.
I'm not looking to spend $$$ on this. If I don't have problem then awesome!
I'm not wealthy and don't just have $20,000 to blow.
But if there is problem I want to fix it. That's all.
Old 03-19-2017, 08:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #143 (permalink)
icemann427's Avatar
Since you say you aren't smoking, you don't need guides. End of story...
Old 03-19-2017, 08:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #144 (permalink)
Forced Induction Junkie
WERK I's Avatar
There's one sound that remotely sounds like a "sewing machine". That's a dry cam lobe/rocker. That means clogged cam tower spray bar. For your sake, I hope it's not....
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 03-19-2017, 08:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #145 (permalink)
What about paint too? The original paint is old now and should probably be replaced.
1987 GP White 930
1977 Ford Bronco
Old 03-19-2017, 09:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #146 (permalink)
"There's one sound that remotely sounds like a "sewing machine". That's a dry cam lobe/rocker. That means clogged cam tower spray bar. For your sake, I hope it's not...."
Oh boy, now you've done it..
Old 03-20-2017, 04:47 AM
  Pelican Parts Technical Article Directory    Reply With Quote #147 (permalink)
Chain fence eating turbo
Yeah, wasn't sure if serious or trolling? HAHA
Old 03-20-2017, 05:25 AM
  Pelican Parts Technical Article Directory    Reply With Quote #148 (permalink)
WERK I's Avatar
Both!
Dave
Old 03-20-2017, 06:18 AM
  Pelican Parts Technical Article Directory    Reply With Quote #149 (permalink)
Shouldn't the focus of this whole post shift to the facts that are established. The engine appears to be better than good and healthy and the owner is paranoically imagining scenarios not entered into evidence . And everything would be answered with a simple compression and leak down test. And I'd venture to say that all of the shops he is shopping are either crooked or incompetent for not ordering the leakdown and compression tests before agreeing to whatever they are wanting to do
Old 03-20-2017, 08:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #150 (permalink)
No shop told me they wanted to overhaul the engine..
I wanted to if needed.
Two shops told me a top end overhaul was out of the question. They only do complete overhauls.
The current shop is looking at the car now.
Old 03-20-2017, 08:12 AM
  Pelican Parts Technical Article Directory    Reply With Quote #151 (permalink)
The path of the warrior.
Rodsrsr's Avatar
Dont forget the interior.
To GI or not to GI.....
Fear the Heel Hook
1976 Turbo Coupe 3.2
2009 Carerra S (997.2)
Old 03-20-2017, 08:13 AM
  Pelican Parts Technical Article Directory    Reply With Quote #152 (permalink)
Tug68's Avatar
Make sure they take out the old air in the tires and put new air in.
Tim
87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost....
85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims.
Old 03-20-2017, 08:28 AM
  Pelican Parts Technical Article Directory    Reply With Quote #153 (permalink)
WERK I's Avatar
Compression and Leak-down tests are an invaluable tools, but don't leave out mandatory visual and auditory inspections. A simple "tick" sound can be misinterpreted as a mechanical noise and actually be an exhaust leak. For those who have worked on these engines, this is common sense.
Dave
Old 03-20-2017, 08:56 AM
  Pelican Parts Technical Article Directory    Reply With Quote #154 (permalink)
beancounter
jwasbury's Avatar
While I understand the desire to have your 930 "right", the only way you'll know if its "right" or not is to drive it. 1700 miles in 20 years? Who cares how it runs? As long as it moves under its own power you're fine for your use case. Take the 20k you were planning to spend on the overhaul and buy a beater and spank the crap out of it daily.
Old 03-20-2017, 10:15 AM
  Pelican Parts Technical Article Directory    Reply With Quote #155 (permalink)
Large Member
krasuskyp's Avatar
AH YES - *now* this thread is on track
phew.
Paint / interior. bwaHA!
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 03-20-2017, 12:35 PM
  Pelican Parts Technical Article Directory    Reply With Quote #156 (permalink)
Well
Sent from my SM-N910T using Tapatalk
Old 03-20-2017, 01:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #157 (permalink)
Norm K's Avatar
phew.
I hear that Paul, a compressor incarnate, is capable of activating a Shrader valve using only his mouth, perhaps proving invaluable in this sort of endeavor should the OP, with everything else he's already fretting over, decide that new air is in order.
_
`66 912: Lone Gone, `80 930: Sold, `84 Targa: Sold, `83 Targa: Sold, `75 S: Sold
Old 03-20-2017, 02:12 PM
  Pelican Parts Technical Article Directory    Reply With Quote #158 (permalink)
Knee Pads are Overrated!
Rawknees'Turbo's Avatar
Originally Posted by Norm K View Post
I hear that Paul, a compressor incarnate, is capable of activating a Shrader valve using only his mouth, . . .
A lowly Shrader valve?!?! Hellz, Paul can activate the main, hydraulic cylinders of the most ginormous of ginormousness forklifts in existence, and not even get tired in the process! The bisch can huff and puff like no other (only IcyHottStuff gives him a run for his money)!
Old 03-20-2017, 02:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #159 (permalink)
Ok engine is in good working order. He said he didn't hear any valve noise that is not inherent with well a maintained 3.3. I was told I have a very nice car and well maintained.
Now the bad news.
The clutch is bad.
The motors mounts are VERY bad.
The CIS injection system needs gone over.
The cold air circuit is not functioning.
Several wiring issues
The ride height is wrong.
Several parts missing from the car.
That said I'm fixing EVERYTHING he can possibly find. The bill is around $14,000
Old 03-20-2017, 02:37 PM
  Pelican Parts Technical Article Directory    Reply With Quote #160 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
