Originally Posted by TurboKraft View Post
Nice DIY job!
Why the "RWB" in the rear wing -- is that one of theirs?
Originally Posted by copbait73 View Post
Regarding your flares. Are you planing to use the fabricated extensions seen in your pictures or do you produce a mold from these to produce the final pieces?
On my photos, extensions are molds. Then, I stick three coats of carbon and I unstick them. Extensions make 1,5mm of thickness in the end.
Old 04-06-2017, 11:19 PM
I looked for an spoiler in carbon for my project. I bought this second-hand spoiler and letters were already inside by its former old owner, I had not the choice.... I believe that I am going to block them it will be better.
Old 04-06-2017, 11:30 PM
hi, friend
you are really a great person, it is a great work to modified the car. perfect!
Old 04-06-2017, 11:37 PM
TurboKraft's Avatar
Originally Posted by YODA MASTER View Post
It is a RWB replica. The difference is that the complete body kit is in carbon. The roof is in carbon too.....I am proud that you tell me that I do the good job, because Turbokraft is very known in FRANCE. Thank you
All carbon? Very nice, indeed! Looking forward to the results.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-07-2017, 08:39 AM
Now I am going to weld it with the TIG
Old 04-07-2017, 09:18 AM
Hi Christ,
I have a question for a specialist like you, because In FRANCE, we are poor of specialists in turbo Porsche, then I hesitate :
For my project with one turbo PRECISION 6262 SP, (low boost 6 psi) it is better a T3 turbine with A/R.63 or A/R.82 ?????
Thank you very much.
Old 04-07-2017, 06:47 PM
3 restos WIP = psycho
kenikh's Avatar
Seems .63 for faster spool and less top end boost would be better.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-07-2017, 08:20 PM
copbait73's Avatar
You do not have a turbo motor. You have a highly evolved naturally aspirated engine. In stock form it is a large engine with great bottom end response matched with a great gearbox. You do not need boost before 3500 and you only need a low level from there on up. I would go for a larger Garrett GTX40-45 size turbo. Let that engine breath.
Old 04-08-2017, 05:24 AM
IMR-Merlin's Avatar
Nice looking car and cool project. I was able to sit right at 2500 lbs with a full cage and all steel bodied 930, I am willing to bet you'll get much lower. This thing will be a BLAST to drive.
What trans are you using?
82 twin plugged, EFI, G50 930, RSR suspension (soon to be) GT35R...
Old 04-08-2017, 07:57 AM
I think, that T3 turbine with stage 5, A/R .82 is a good choise
Old 04-09-2017, 07:43 AM
TurboKraft's Avatar
If possible, T04 flange 0.82. If not, then T3 flange.
Stage-5 turbine
And a big wastegate -- you will need to bypass a lot of exhaust energy since you are running a high compression engine and basically using the turbo like a supercharger.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 04-10-2017, 10:15 AM
thank you Chris for your answer... I think put in a 44mm wastegate.
Old 04-11-2017, 02:29 AM
Old 04-29-2017, 11:49 PM
Old 05-13-2017, 02:28 AM
Very nice TIG work. That looks like Sch.10 pipe - .120" (3 mm) wall? Heavy but so much easier to work with, no rod needed, just fusion weld.
Old 05-13-2017, 03:40 AM
Chain fence eating turbo
That is old-school, choke city!!!
I wouldn't use anything smaller than a "P"-trim turbine and T4 flange on a 3.6.
Stage 5 is kind of small.
Let her breath up top!
Modern turbines spool extremely quick comparing to old designs. No need to use a small turbine and A/R housing.
Old 05-13-2017, 03:56 AM
Thanks...
but I have a max boost 7 or 7.5 psi before intercooler and 6 psi after...I think that "P"-trim turbine and T4 flange on a 3.6 is bigger for low boost, no?
Old 05-13-2017, 08:39 AM
exactly
Old 05-13-2017, 08:43 AM
[img]http://forums.pelicanparts.com/uploads26
Old 07-01-2017, 02:52 AM
Old 07-01-2017, 02:54 AM
