911 3.2 with 993 supercharged engine
Hi,
I live in France, and I come back with a new project. It's a 911 3.2 1985, and I put in a 993 carrera engine and 993 gearbox, with a single turbo 6262 precision with T3 turbine A/R82. It's a low boost with 6 psi. http://forums.pelicanparts.com/uploa...1491333141.jpg http://forums.pelicanparts.com/uploa...1491333220.jpg http://forums.pelicanparts.com/uploa...1491333238.jpg http://forums.pelicanparts.com/uploa...1491333257.jpg [img]http://forums.pelicanparts.com/uploads26 /15385500_1909466342619909_7293650987905206952_o149 1333311.jpg[/img] http://forums.pelicanparts.com/uploa...1491333824.jpg http://forums.pelicanparts.com/uploa...1491333843.jpg http://forums.pelicanparts.com/uploa...1491333864.jpg http://forums.pelicanparts.com/uploa...1491333895.jpg http://forums.pelicanparts.com/uploa...1491333921.jpg http://forums.pelicanparts.com/uploa...1491333936.jpg |
http://forums.pelicanparts.com/uploa...1491334273.jpg
a new with 72mm http://forums.pelicanparts.com/uploa...1491334380.jpg http://forums.pelicanparts.com/uploa...1491334393.jpg http://forums.pelicanparts.com/uploa...1491334489.jpg 3.2 X3 male connector (engine) 993 X3 femelle connector (chassis) http://forums.pelicanparts.com/uploa...1491334818.pnghttp://forums.pelicanparts.com/uploa...1491334948.jpg |
Sub'd.
Should be about 450hp maybe at that boost? Gonna be a sweet ride! Cool project! |
http://forums.pelicanparts.com/uploa...1491340284.gif
X3 connector for blower, heaters, alternator, ignition, oil pressure and oil temp..................... http://forums.pelicanparts.com/uploa...1491340298.jpg X4/1 and X4/2 and X60 for DME, relay DME, belt tensionner, injectors....... http://forums.pelicanparts.com/uploa...1491340307.jpg connection between relay DME and DME |
Awesome!
http://forums.pelicanparts.com/uploa...1491462140.jpg
http://forums.pelicanparts.com/uploa...1491462164.jpg http://forums.pelicanparts.com/uploa...1491462196.jpg http://forums.pelicanparts.com/uploa...1491462273.jpg http://forums.pelicanparts.com/uploa...1491462298.jpghttp://forums.pelicanparts.com/uploa...1491462338.jpg http://forums.pelicanparts.com/uploa...1491462361.jpg |
http://forums.pelicanparts.com/uploa...1491462669.jpg
Today, I make the intake pipe between the futur MAF and the compressor turbo. 76mm diameter |
Cool kraftwork! Dig the collector edition Wurth calendar... wish I still had that one.
Cool, subscribed.
Like the custom body fab.
Subscribe |
Nice DIY job!
Why the "RWB" in the rear wing -- is that one of theirs? |
It is a RWB replica. The difference is that the complete body kit is in carbon. The roof is in carbon too.....I am proud that you tell me that I do the good job, because Turbokraft is very known in FRANCE. Thank you |
Regarding your flares. Are you planing to use the fabricated extensions seen in your pictures or do you produce a mold from these to produce the final pieces?
Your work looks great, why would you put someone else's name on it?
^^^ Exactly. The Porsche 934 started the super wide flair style not RWB.
No need to give him credit for your car. |
Cool car! Yeah I was confused as why you'd put RWB on the back. That engine bay looks amazing. Keep it up.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
