-   -   930 manual boost controller valve console (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/956784-930-manual-boost-controller-valve-console.html)
reclino 05-15-2017 01:50 PM
Looking for dimensions of this part. It mounts the 935 boost control regulator between the seats in a 930. I just got a sheet metal brake so should be easy to make.
http://forums.pelicanparts.com/uploa...1494881330.jpg
reclino 05-15-2017 02:25 PM
This looks like the same style.
http://forums.pelicanparts.com/uploa...1494883461.jpg
http://forums.pelicanparts.com/uploa...1494883482.jpg
http://forums.pelicanparts.com/uploa...1494883500.jpg
dg567 05-15-2017 05:24 PM
Here are a few pics of one I just got http://forums.pelicanparts.com/uploa...1494894261.JPG
Let me know if you want some measurements
reclino 05-16-2017 04:22 AM
Yes, I will make one of each and see which one I like better.
reclino 05-19-2017 08:25 AM
Ayone else have one of these they can measure?
1100sport 05-25-2017 12:43 PM
There are other ways of doing it :-)
http://forums.pelicanparts.com/uploa...1495741271.JPG
patina 05-25-2017 06:00 PM
really gorgeous
kenikh 06-01-2017 06:01 PM
I so want that
Sent from my Nexus 6P using Tapatalk
onboost 06-02-2017 08:21 AM
My old Andial unit.. now in for a refresh!
http://forums.pelicanparts.com/uploa...1496416787.jpg
john p 06-02-2017 06:17 PM
Interesting all this. My 1979 Kremer came with the boost controller mounted in the centre console, where the tapes where stored, Have seen some Kremer 930's with it mounted at the rear
happy with the console mounting because :
Cannot be knocked when fitting seat belts or rear passengers
Most 935"s ( mine included ) were mounted forward, helped orientation of increasing / decreasing boost
Looks better ( great looking bit if gear )
Arthritis, easier to reach forward than back !!!
onboost 06-06-2017 04:54 AM
The whole idea for rear mounting was to make it more difficult, and less of a temptation to turn the knob. Some people can't resist the temptation and we know what happens when you turn it too far!
reclino 06-06-2017 06:08 PM
I like the pictures, but would be better if shown with ruler for scale, even better if some one could use the ruler and report back some dimensions.
Bucketlist 06-07-2017 05:28 AM
I really like it in the console, sad I pulled the hoses from it last year.
My DOD is the most popular conversation piece at car shows, love it.
Just got my waste gate squared away with a new diaphragm and fittings, dropped from the 1.2 bar that I love to the .5 that I don't. Next step may be to reattach the hoses, or maybe find a .9 spring.
http://forums.pelicanparts.com/uploa...1496838343.jpg
Bucketlist 06-09-2017 09:37 AM
Sorry I can't help with your console measurements, but let me bother you with a question.
My valve has the vertical chambers open
http://forums.pelicanparts.com/uploa...1497025442.jpg
Are yours plugged top and bottom?
http://forums.pelicanparts.com/uploa...1497025804.jpg
reclino 06-09-2017 10:43 AM
Plugged
1100sport 06-09-2017 01:27 PM
Same here.http://forums.pelicanparts.com/uploa...1497040008.JPG
MDPorsche 06-14-2017 10:52 AM
What is the boost range adjustment for the "dial of death"?
1100sport 06-14-2017 01:07 PM
The range is 0,8b. So putting a weaker spring in the WG is a must. As I wished to keep my factory WG (true piece of Motorsport history fitted to 934/935/956...), I put the weakest spring available i.e. the 0,5b one from the 924 Turbo.
So technically my range of adjustment is 0,5b to 1,3b... having a tell tail boost gauge is very helpful to check where you're at when making adjustment.
You can still add a bolt on the adjusting screw to reduce travel as a safety measure.
VZ935 06-15-2017 08:53 AM
I have a bunch of these (the spare knob is reserved for Marco tlg)
http://forums.pelicanparts.com/uploa...1497541986.jpg
reclino 06-15-2017 12:47 PM
Got any pictures of the inside of the regulator? I suspect the diaphragm is made of in inconel but my original one still works and don't want to risk taking it to pieces.
MDPorsche 06-15-2017 03:58 PM
Who is making selling these wonderful devices?
VZ935 06-16-2017 07:35 AM
I have one left
http://forums.pelicanparts.com/uploa...1497623728.jpg
TurboKraft 06-16-2017 10:19 AM
Originally Posted by VZ935 (Post 9628560)
$? I'm interested.
VZ935 06-16-2017 11:00 AM
Originally Posted by TurboKraft (Post 9628761)
$? I'm interested.
For you Chris?
http://forums.pelicanparts.com/uploa...1497636048.jpg
TurboKraft 06-16-2017 03:48 PM
Would you take a laser-beam-fitted shark in trade?
Garen 06-16-2017 07:40 PM
Chris wins... All I have are laser-beam-fitted Sea-Bass...
Maltese Falcon 06-17-2017 07:23 PM
Looking good Van ! ...would look better than my funky old Parker/ Hannafin in my new build
Maltese Falcon 06-17-2017 07:40 PM
Van....guess I'll wait it out for your next run of Steam-wheels, gotta look sharp for this build:D
http://forums.pelicanparts.com/uploa...1497753527.png
Sorry, pic won't load up
