965 3.3 Idel ajustment question
Hey guys
I have plenty of experience with m y old 3.3 turbo, But not with the 965 3.3, very much the same but with a few controllers doing some of the adjustment for me, My 965 starts perfect warms up perfect, runs perfect ,
At cold start she goes to 1100 rpms, the goes down to 750, I would like to rise the RPM's to 950, because I like the sound track better at higher RPM'S and it helps with scavenge oil pump for the turbo.
Question...... is if I just bump up the idle to 950 will it mess with my tune, I don't think it should but what do you think ?
thank you
Helio
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 05-23-2017, 10:27 AM
Jeff NJ's Avatar
My understanding is that the idle adjust really only affects it at idle. Once you open the throttle, the position of the idle speed screw is immaterial to the mixture.
Easy enough to change and then change back if it causes unintended problems...
Edited to fix what I meant to say - idle speed screw insteam of idle mixture screw.
1988 930 Venetian Blue
Old 05-23-2017, 11:52 AM
Metal Guru
911nut's Avatar
Turning the idle speed adjustment screw is analogous to cracking the throttle open with your right foot. It has no effect on tune. In other words, it's not like messing with the idle mixture screw on the air sensor plate or control pressure. It just makes the engine run faster.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 05-23-2017, 01:06 PM
Originally Posted by 911nut View Post
+1
That makes sense, I just wanted to make sure, I've been down that slippery slope, we all have...lol
1992 964 C2 turbo
Old 05-23-2017, 01:31 PM
