SBK930's Avatar
270 degree thrust bearing success.
Well at least it's looking that way so far.
Installed the 3rd time rebuilt k27 7006 back into my baby today.
The rebuilder used a 270 degree thrust bearing this time, only after I sent a warranty claim and explained to them that the Borg Warner upgrade thrust bearing could be the problem as I had learnt from some of the posters here at pelican.
To note: I found while running the engine it appears there is far less oil running through the turbo and into the drip tank. So much so that the scavenge pump sucked the container virtually dry. Whereas previously the scavenge pump just kept up with the oil flow out of the drip tank. Not sure what to make of this.
Here is a short vid of it.
https://m.youtube.com/watch?v=YlcWojLbY7g
Old 05-26-2017, 12:24 AM
T77911S's Avatar
that might be a good thing.
if there was too much play in the bearings the oil could have been going thru them too fast. it seemed like the oil coming out of my new turbo was slow too. 7006.
was there any shaft play on the last rebuild?
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 05-26-2017, 04:45 AM
SBK930's Avatar
No
At least so far the oil is not pumping through the compressor and turbine sides of the turbo.
The second rebuild was worse than the first.
Old 05-26-2017, 08:53 AM
Jeff NJ's Avatar
It doesn't need a lot of oil to be lubricated properly. Congrats on hopefully solving this!
Less oil in there means more heat in the oil, so especially if you're not using synthetic oil, be sure to give the turbo some time to cool off before shutting down or you will coke up the oil in the cartridge. I always take it easy the last few miles coming home and then let it idle for a minute or so before shutting down.
1988 930 Venetian Blue
Old 05-26-2017, 12:48 PM
SBK930's Avatar
Thanks for the tip mate, and yes I am using synthetic.
Old 05-26-2017, 12:55 PM
Jeff NJ's Avatar
Since it has a far higher flash point than dino oil, it is MUCH less susceptible to coking, but still a wise habit to let it cool off before shut down for a long and healthy turbo life.
Old 05-26-2017, 01:05 PM
