-   -   FS and WTB -- replace short 4-speed with correct long 4-speed (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/958798-fs-wtb-replace-short-4-speed-correct-long-4-speed.html)
TurboKraft 06-02-2017 11:53 AM
Hello everyone,
Posting this to the Turbo forum as this would be on page 3 of the classified by the end of the day.
We have a 1978 930 in the shop for restoration. It hasn't run in 30 years -- not a typo -- and not much history on it's past life.
Despite very low miles, someone had installed an incorrect "short" 1976-77 930 4-speed in it. Not only is it the wrong transmission for the otherwise very original car, but it also moves the engine approx. 1" too far forward so there's interference with the engine sheetmetal, rear wiper motor, etc.
We're wanting to source and install the correct "long" 1978-79 930 4-speed, and sell this short 1976-77 4-speed.
If you have a correct long 4-speed available, or need a need a short 4-sp, please contact us.
Thanks,
lite75 06-02-2017 01:36 PM
Chris,
Free up some space in your mailbox.
Thanks!
TurboKraft 06-02-2017 04:32 PM
Done, thanks for the heads-up
Matt Monson 06-02-2017 06:06 PM
That short box is worth about twice a long one.
Matt Monson 06-02-2017 08:15 PM
Kris,
I just thought of someone. I'll ping you tomorrow. I think I know a way to help you. I just need to check what year his box is.
Rawknees'Turbo 06-02-2017 08:42 PM
***forum dating***
911tracker85 06-03-2017 04:58 AM
I need that but probably cannot afford it.
got a long 930 4sp with plans to rebuild and shorten the bell housing for my 78 SC/930 conversion project.
got a used 930 4sp that turned out to be totally unrebuildable junk. still trying to work with seller on a resolution. if not I will name them and shame them on this forum.
good luck, always enjoy seeing your posts Chris.
Matt Monson 06-03-2017 07:50 AM
Gave Darkstar1 a heads up about this thread.
LSR911 06-04-2017 09:00 AM
I have a few 930 long transmissions here in Phoenix. PM Sent.
LSR911
Darkstar1 08-04-2017 05:20 PM
Mine is still at Rader Motorsports. Been busy so forgot all about it. Email me if interest in a long 930 gearbox. Randyemoore1 AT aol.com
Randy
Darkstar1 08-07-2017 01:22 PM
Thanks for the attempted hookup Matt!
Matt Monson 08-07-2017 08:50 PM
You're welcome.
jjeffries 08-13-2017 11:15 AM
In the spirit of "always be learning", which model is the short 4 spd intended for? Is it a poor man's 915 from a 912E, or is it a legit 930 unit?. Just inquisitive. Thanks, John
quattrorunner 08-13-2017 01:33 PM
Available from 75-77. It's shorter bellhousing to fit the engine compartment of the 911. It houses the same gearing as the longer bel housing.
Matt Monson 08-13-2017 02:15 PM
It's a regular 930, the first couple years we're just about 30mm shorter on the clutch hell housing end.
911tracker85 02-21-2018 07:24 AM
Chris,
is that short gearbox still available? pls PM me,I am on a quest for a gearbox for my 78 SC/930 conversion project.
TurboKraft 02-21-2018 08:05 AM
No, turned out that the PO had modified the chassis and shifter for the short box so the current owner opted to reuse it.
1100sport 02-21-2018 09:09 AM
You mean he kept the engine in the same location as in a 3.3l and moved the transmission beam/shifter location rearward to accommodate the short bell??
TurboKraft 02-21-2018 09:49 AM
Engine in stock location.
Transmission crossmember was reversed and curving forwards.
Shift coupler and rod had already been modified.
1100sport 02-22-2018 08:22 AM
Thanks for responding. I struggle to understand the rationale but then it is not my car. I guess they broke the gearbox and all they could find was a short bell. Too bad they did not take advantage of it.
TurboKraft 02-22-2018 12:16 PM
Impossible to know, that was over 31 years ago.
Prior owner also opted to color change the car from Light Blue Metallic to Guards Red. Probably seemed like a great idea at the time.
Mr9146 02-22-2018 02:08 PM
"And the Gods rained down fire and brimstone on the people for their wickedness..." SmileWavy
Lukesportsman 04-04-2018 05:54 PM
Are you still looking to trade for a long box? I think I might have two, but will have to look in shop.
TurboKraft 04-05-2018 09:22 AM
Hi Luke,
Thanks for the response.
Per post #17, the current owner opted to reuse it.
TurboKraft 04-05-2018 09:24 AM
Thread closed
