-   -   Wastage Spring Identification (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/959264-wastage-spring-identification.html)
ivanuf 06-07-2017 07:42 AM
Need help to identify this spring.
From other spring id postings, I could not find one that matches this one
This one as you can see on the picture has 6 loops and is slightly taller than others
that are on past postings.
http://forums.pelicanparts.com/uploa...1496849737.jpg
Here are the measurements:
Width = 2.706"
Wire thickness = 0.192"
Uncompressed spring length/height = 7.6250"
From other members and past postings I understand that stock pressure for 76-77 930 wastage spring was 0.6 bar, is this correct?
Is this the factory spring or is it an upgraded spring?
Ivan
ivanuf 06-08-2017 06:03 AM
A member wrote to me the following message:
That spring looks to be a 0.8 bar spring from a 3.3 although I typically see 0.196" wire diameter on the oem 0.8 bar 3.3 springs. What you car do you have?
I have a 77 turbo with 3.3 bottom end (pistons and heads) so I guess it has a 0.8 bar spring from a 3.3 turbo?
kenikh 06-08-2017 03:39 PM
I've tried all of these measurements and they are so inconsistent as to be useless.
Sent from my Nexus 6P using Tapatalk
Handyjay 06-10-2017 06:26 AM
For what it is worth I Just measured a .8 bar spring as follow: diameter .210, width 2.726, and 6.375 long.
