'76 911S 3.0's Avatar
Turbine Flange Angle
Does anyone have the measurement of the angle at which the turbine inlet flange sits with the headers parallel to the ground? ie: if you have the headers resting on the ground, or a flat surface, what is the angle at which the turbine inlet flange sits?
Reason I ask, I am having a set of headers modified and want to ensure the angle is correct before having everything finish welded.
Thanks!
Old 06-12-2017, 03:29 PM
