G60SuperCharger's Avatar
1976 930 Sway bar install...no clearance from transmission support bar
Hi there,
I have a 1976 930 which I got in a partially disassembled state. In remounting the sway bar, I had no problem getting the drop links installed, but the bar hits the lower transmission support bar so I can't install the brackets (with bushings) that bolt to the body (one on each side, two bolts each).
Any ideas what the problem could be?
Old 06-15-2017, 02:19 PM
Try flipping it over ask me how I know
Old 06-15-2017, 02:24 PM
Thans...below is the swaybar system I'm working with...is this what you had? I think they changed to a different one in 1978.
So you just flip the bar over such that the bar end that went into the left side end link will now go into the right side end link instead?
Old 06-15-2017, 04:29 PM
Old 06-15-2017, 04:31 PM
Sorry mine is different
Old 06-15-2017, 04:57 PM
Non User
infraredcalvin's Avatar
Pics, but you Might have the wrong trans mount. I'll stick my head under mine tonight and see what I can see...
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 06-15-2017, 05:37 PM
Non User
Wait, did you install the drop links to the trailing arms before mounting the bar to the chassis? There is a quite a bit of preload on the bar with car on the ground...
Old 06-15-2017, 05:39 PM
I did install the drop links to trailing arms first. Maybe that's the problem. I'll give it a try. This is a super original, 32,000 mile car, so I doubt the trans mount has been replaced.
Old 06-15-2017, 09:01 PM
You have the wrong swaybar,not easy to find the right 3.0 only one.
Found one here trough a wtb
Old 06-15-2017, 09:35 PM
So the rear swaybar's shape is unique to the 3.0 930? I tried to find a picture of one but no luck. Any chance you could send a quick pic?
Old 06-16-2017, 06:02 AM
WTB Early Turbo Carrera swaybar 18mm
Old 06-16-2017, 10:10 AM
I have a 76 turbo sway bar i would sell
Old 06-17-2017, 09:45 AM
Thanks guys. Chris I will send a pm
Old 06-19-2017, 08:56 AM
