-   -   Part number help please AAR hose (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/960660-part-number-help-please-aar-hose.html)
Mike80911 06-18-2017 05:47 PM
I have looked but I get distracted easily and have not been able to find the part number for the hose that goes from the AAR valve to the intercooler. Can someone please identify the part number for me?
Dmitry at Pelican Parts 06-19-2017 09:15 AM
Hi Mike - if our members don't get back to you with the part #, feel free to give us a call at 888-280-7799 and one of our Porsche part specialists will be able to help you out.
Mike80911 06-19-2017 10:34 AM
Thank you I got the number I will order it soon
Rich76_911s 06-19-2017 10:41 AM
Looks like it is part 999-239-009-40.
Rubber Hose 99923900940 - Genuine Porsche - 999-239-009-40 | Pelican Parts
If I'm correct about the dimensions Pelican gives it appears to be a 27mm outside diameter - 18mm Inside diameter hose. 18mm is about 3/4 inch, so maybe you can just get some standard 3/4 inch hydraulic hose and that could be a cheap replacement. I'd check the inside diameter before I went buying anything though. If you need me to pull my hose and check the inside diameter I can do that.
Cheers
Rich
1979-930 06-19-2017 11:38 AM
Originally Posted by Rich76_911s (Post 9632206)
If you need me to pull my hose... I can do that.
Cheers
Rich
Quite an offer :eek:
Rawknees'Turbo 06-19-2017 11:43 AM
Definitely a brother from a different mother! :D
Mike, heater core hose works perfectly there (is thick walled, so holds shape nicely and does not kink - though there is noting wrong with "kink", buttofcourse! :eek:). You can easily find the right size at any autoparts store, Ace hardware, etc.
