Boost gauge key
Can you still get the little key with the internal broached triangle that turns the telltale back on these boost gauges, and if so, where? I used to have a couple, but that was 15 years ago and I have no idea where they went nor where to get a replacement.
Tracy
Old 07-17-2016, 11:04 PM
WPOZZZ's Avatar
Try North Hollywood Speedo or Palo Alto Speedo.
Old 07-18-2016, 02:05 AM
IMR-Merlin's Avatar
I just modified a tire valve removal tool with some needle nose pliers until I found my key under the carpet.
82 twin plugged, EFI, G50 930, RSR suspension (soon to be) GT35R...
Old 07-18-2016, 06:26 AM
Thanks guys. I forgot all about North Hollywood Speedometer, I'll give them a shout. IMR-Merlin, I did more or less the same thing drilling and crushing a little piece of aluminum round stock. Functional, but it's fugly and not quite right. My real one was on a key ring that got lost 15 years ago. At least I had sense enough to leave the actual key in the switch when I put her in hibernation.
Old 07-18-2016, 09:28 AM
Speedfab,i am wondering if you use this on a 76' 930?
I am on the same route and wondering where to hook up the airline of the gauge?
I think it goes on the intake,might you have a pic of that point?
Thx
Old 07-28-2016, 11:10 AM
Dwerkz - My car has a separate pressure reference line running to the front, it is not a factory turbo car. On yours you can simply tee into the brake booster vacuum source line. Alternatively I believe there is a brake booster check valve that has a gauge nipple made into it, I'm sure one of the guys on this forum knows. Pelican probably carries it?
Someone who knows where to get one of those things please help this guy out.
Old 07-28-2016, 11:47 AM
Mr9146's Avatar
Power brakes didn't make their Porsche debut until 1977. It's likely Dwerks is asking because he has a 76 car.
The answer is the same ... run a dedicated hose from the back of the car to the front of the car.
Old 07-29-2016, 05:11 PM
Non User
infraredcalvin's Avatar
Mine was done by a PO some time ago. The air line is routed from the gauge down through the tunnel into the engine compartment. The line connect s to the intake butterfly valve facing the front of the car.
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 07-30-2016, 12:03 AM
Thx for the awnsers,i will check for you gauge adjuster.
My restore source is a ex VDO employee,maybe he has a lead.
When he is back from vacation i will drop by.
Old 07-30-2016, 12:28 AM
See there, I learned something new today. Thanks Mr9146! For some reason I thought power brakes showed up in 74 with the body changes.
Old 07-30-2016, 09:01 AM
Take a pop rivet, remove center rod. Put it in drill mandrel, tighten. Presto.
Old 08-02-2016, 12:44 AM
bought mine from North Hollywood speedo - had it in about 3-4 days
08 Aston Martin Vantage V-8 (6 spd manual) (DD)
20 Cayenne white-black/red (hers)
78 930 (heavily modified)
08 GT3 RS (white/black) (modified of course)
67 911S outlaw (sold)
Old 08-02-2016, 12:01 PM
Old 08-02-2016, 12:15 PM
What did the reset key cost? Was there a PN to order?
1986 Ruf 930
2015 991 GTS-MT
2006 993 S-MT (Gone)
1969 911 T (Gone)
Old 06-24-2017, 08:03 PM
