-   -   Ignition Map needed, 3.2>3.5 (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/961222-ignition-map-needed-3-2-3-5-a.html)
kuehl 06-24-2017 05:46 AM
Looking for a dyno generated ignition map.
911 3.2 or 964 3.6 normally aspirated stock would be great, and if the y axis is kpa or psi that would be ideal. ECU is an AEM Infinity 506, however I'd be glad to work off of others ECU maps. The more the merrier.
Griff
kenikh 06-25-2017 12:40 AM
Al Kosmal should be able to help.
Sent from my Nexus 6P using Tapatalk
