Boost issues
88 930 SC cams
California Smog car, other wise stock. I'm having issues at rpm (3800 ) plus when boost is involved. Symptom is an acceleration stutter. Stay out of boost by feathering pedal, no issues. Replaced over boost sensor. No change. Fuel pressure after filter 100 psi. Any advise would be appreciated. Thanks, Joe |
Maybe a small air leak somewhere causing boost leak. Check all your boost connections are tight and sealed properly.
Cheers, Chris 1986 951 SOLD: ![]() |
Will do,
Thanks |
I was stumped with my car recently as I had a very intermittent boost leak that I thought was a bunch of other potential problems, but as it showed up more I realized it was a boost leak way down where I have an adapter that fits on my turbo, the seal we slowly getting worse. So i've resealed it and its running good again. Sometime the fix is alot easier than you anticipate.
Also Check all the vacuum hose , including the ones that on the very back , like the Thermo switch
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
i had an issue like that and it was the spark getting blown out under the pressure; like you, feather the throttle and no problems. I put in new plugs and it ran like a champ, I spent several months chasing boost/vacuum leaks. Good luck
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel |
Leak(s) as others have suggested. 99% likely.
Just for your edification and continued education, you said: "Replaced over boost sensor. No change." Understand that said sensor is an on-off switch, and will not cause stuttering or other poor running conditions. It's job is to shut the chit off when overboosting. If suspect, it will completely shut off your fuel delivery...and I mean completely. The engine dies violently, like hitting a brick wall (hence, "face in the dash" has been assigned to this event).
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Turbofrog
Stutter sounds spark problems to me. Swap the plugs like tops suggested.
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg |
Check your connections. My problem was exactly like yours and it ended up being the boost sensor connection on the bottom of my intercooler. The wire would intermitantly disconnect due to being loose. Didnt figure it out until it fell off while I was driving and just as Mark discribed...the engine died.
James 1989 Slate Grey 930...sold ![]() Looking for the next one! |
if you have a boost leak the AFR will be richer.
big enough boost leak and you don't reach max boost. if you have issues with the enrichment from the WUR that will make it run lean. lean will make it run worse before being too rich. you can: pull a vacuum on the WUR to check diaphragm put 10psi of air pressure into WUR and check for drop in CP. check ignition advance
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Could be running too rich under boost threshold.
I interpreted it as the entire time he is on boost.
"3800 plus" as in above 3800
