3.0 1977 Steering wheel rattle
Hello
Havnt posted in a while, but wouldnt know who to ask but this fine group..:
I am driving on a lot of cobble stone recently, with my 77 3.0 turbo. There is a loud rattle in the steering wheel on cobble stone, if I hold the back cover of the steering very firmly, it dims.
I have dismantled, cuhsioned the springs (for the horn), really tried to figure this one out but cant.
Anyone?
Image from recent 3K KM trip Berlin to Lisbon attached, for eye candy
She drove beautifully, 3K KM in 3 days, with half a liter of oil consumed...
Old 07-05-2017, 04:42 PM
Brando
quattrorunner's Avatar
I had the same thing, got a momo, solved it.
Turbo powa!
1977 911s. it's cool
Old 07-05-2017, 04:54 PM
When you hold onto the steering wheel and lift up and down does it seem a little loose? If so it could be your steering shaft going bad. There are aftermarket replacement bushings available that are somewhat easier to install than a factory bushing replacement.
Rahl
Old 07-05-2017, 08:12 PM
Topocalma
I solved my rattle today. Problem was I had rattle / 'thumps' sometimes at high speeds, always at low speeds on cobble stone or similar. However the bearings felt firm.
Turns out the universal joint on the intermediate steering shaft was loose and had play. Not suren if the few turns to tighten the bolt saved me from loosing steering and hurting myself at some point but def fixed my problem.
1973 2,4T gemini blue
1977 3.0 Turbo slate grey
Old 11-18-2017, 01:37 PM
Where do you access the intermediate steering shaft?
Old 11-22-2017, 08:04 AM
Topocalma
Simon,
I tried to do a write-up.. Resolved steering rattle: Loose bolt upper u-joint steering shaft
Old 11-28-2017, 02:57 AM
T77911S's Avatar
Rahl
this first. its easier and cheaper.
you just press the new bushing in and it pushes the old one out.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 11-28-2017, 05:56 AM
Uncertifiable!!!
Uwon's Avatar
Which bushing are you referring to?
Johan
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, A4 Quattro, the RST hot rod-http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst.html
Old 11-29-2017, 10:18 AM
T77911S's Avatar
it is one behind the steering wheel.
928-347-739-02-OEM
Old 11-30-2017, 04:23 AM
Uncertifiable!!!
Uwon's Avatar
Canít remember the setup. Doesnít the old bushing then press against the upper bearing at the dash?
Johan
Old 11-30-2017, 05:34 AM
What Rahl is talking about is the Mitch Leland nylon replacement support bushing, which our host sells for $29. I have one, never opened, that I never used and waited too long to return. I'll sell for $25, including shipping, if anyone needs it.
Here's the part (bottom of page):
Porsche 911 (1974-1989) - Steering System - Page 5
And here's a thread explaining what it does:
Mitch Leland's Steering Wheel Bushing
Old 11-30-2017, 08:06 AM
T77911S's Avatar
I did the 928 bushing on my car. you just knock it in and it pushes the old one out and you are done.
I see the mitch bushing gets great reviews.
Old 11-30-2017, 10:24 AM
Alan L's Avatar
Thats the suspension bridge in Lisbon, right?
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 12-01-2017, 01:16 AM
Old car guy.....
Hot Euro's Avatar
This was one of the first things I did to my car after purchase. Actually on the test drive the steering wheel felt loose, the shifter rattled and had to hunt for the gears a little. This all helped with the negotiation and final price.
I was surprised how easy this fix was, a little easier than the shifter bushings and the shift rod and shift collar bushings. All was tight after these easy mods.
1981 SC Steel Widebody, DP Lid, 930/51 to 3.2l, K27 7006 Turbo, DOD, P&P Twin Plug heads, Twinfire Ignition, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, 044 pump, BLwur, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters
2003 BMW Z4 Daily Driver & Autocross car.
Old 12-01-2017, 04:18 AM
Alan
Yes it is! Great to drive around there, along the Atlantic ocean to a seafood place
Old 12-02-2017, 01:01 PM
This is great, I will do this asap and revert.
I did check the steering wheel off move to check the bushings and moved the steering column for play - no play. Almost impossible for the rattle to come from there, as it is clearly metallic, on cobblestone it feels like a loose screw or mounting. Steering has zero play, either.
Old 12-02-2017, 01:03 PM
The next time you can pick me up in Leonberg and we drive together.
Dominik
Old 12-02-2017, 08:24 PM
