Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
jwakil's Avatar
Thinking of rewiring my whole dam* car
After fighting electrical gremlins for the past year --fuel pump circuit, parking light circuit, AC....I'm thinking about gutting all the electricals from my 930 and rewiring with a new harness. Tired of chasing shorts and opens, some of which I still haven't tracked down. Is there anyone who makes harnesses for a Euro 930? Probably not but thought I would throw it out there....
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 07-07-2017, 11:39 AM
Chain fence eating turbo
There is
Timmy2?
Old 07-07-2017, 11:55 AM
somoney311's Avatar
Building SC and Mid Year Engine Harnesses
https://r.tapatalk.com/shareLink?share_fid=844&share_tid=740894&url=http%3A%2F%2Fforums%2Epelicanparts%2Ecom%2Fsho wthread%2Ephp%3Ft%3D740894&share_type=t
Search username timmy2. He builds harnesses but will probably need the old one as a guide. He usually does engines only but has done other early model cars in the past.
James
1989 Slate Grey 930...still tinkering
Old 07-07-2017, 11:56 AM
3 restos WIP = psycho
kenikh's Avatar
Dennis (aka Timmy2) = problem solved.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-07-2017, 02:45 PM
Uncertifiable!!!
Uwon's Avatar
Re-wiring is a daunting task. I moved the wiring from a crashed '86 to my RST build and it took me probably four months devoting 20hrs/wk to get sorted out, and that was with no motor, pedals and interior. Included some re-wiring, but not much. The biggest PITA is removing and replacing the wiring thru the tunnel and around the pedals area(which I think would have to be removed in your case).
I don't know if you can even find enough wire color combinations to make heads or tails of the end result.
Notwithstanding, you should contact Timmy2 for expert advice. He did a fabulous job which my engine re-wiring.
Cheers,
Johan
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, A4 Quattro, the RST hot rod-http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst.html
Old 07-08-2017, 03:37 AM
911tracker85's Avatar
almost have my wiring totally torn out of my tub. already exchanged notes with Dennis about having him build all new harnesses. custom, as I do not plan to reinstall a lot of stuff such as pwr window, pwr mirrors, courtesy lights, etc. and want some customer independent switches for the FPs and dual ign and gauges.
got this car with engine bay burned wiring due to cracked muffler spewing hot exhaust up into the engine bay.
did not want to totally strip and rebuild this beast and then chase wiring issues for the rest of my life....
good luck, will watch for your posts rewiring.
Bob Cox
84 928S, Ruby Red linen/brown interior - preferred DD
85 911 Targa, White Gold/brown int - retired from track.
86 944 turbo my new DE/track car.
78 930 clone project car.
Old 07-08-2017, 07:56 AM
I feel your pain brother!
While not on my 930, I had the engine wiring harness hacked to sheet by the former owner on one of my other "fun" cars and had to buy a whole other running car to donate and harvest the harness.
BTW I'm in Houston too.
Old 07-08-2017, 01:39 PM
You might consider a motec power distribution module if you go this route. The PDM replaces all the circuitry including fuses, relays etc. Not cheap, but highly customizeable.
Old 07-09-2017, 04:43 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
