Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
air-fuel ratio
What is the best way to measure afr?
1988 930
Old 07-17-2017, 06:12 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
3 restos WIP = psycho
kenikh's Avatar
This: PLX Devices DM-6 SM-AFR Gen4 Gauge Combo UEGO AFR Air/fuel Ratio Bosch LSU 4.9 Wideband Oxygen Sensor Controller with 2 1/16" (52mm) OLED touch screen multi gauge. https://www.amazon.com/dp/B00U1J1MCK/ref=cm_sw_r_cp_apa_wYlBzbZQF5KCR
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-17-2017, 06:33 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Jeff NJ's Avatar
I have what Kenik suggested. I like it. There are other good ones too, of course.
Are you in zip code 07845? If so, I am like 10 mins from you in Mt. Arlington. Would be happy to get together to show you what I have and how it works on my 88.
1988 930 Venetian Blue
Old 07-17-2017, 07:56 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Something to keep in mind is most of these are installed in front engine cars and the cable is around 8 feet long so you need to buy one that has a much longer plug in cable available so you can install it in a rear engine car.
The wideband oxygen sensor for it should be installed after the turbo according to instructions that come with it. Exhaust back pressure in the headers can distort wideband AFR readings if it's mounted before the turbo and if the O2 sensor ever had any pieces burn or break off you don't want them going through the spinning turbo.
When I had a 930 I installed one of these Innovate AFR gauges with the longer Innovate cable they make for it. They come with white and black bezels and face plates so you can use whatever looks best in your car.
Never had any problems with it and it always worked well.
Looks like the price has gone up a bit since I bought one and ebay sellers may have the lowest price.
Innovate MTX-L Digital Wideband Air Fuel UEGO O2 Controller Gauge 3844 | eBay
Old 07-17-2017, 09:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Jeff NJ's Avatar
Yes Jim, the cable length is certainly something to be sure about when purchasing. I mounted the PLX controller boxes under the driver's seat and all the stock cable lengths (to the display unit and to the Bosch sensor) were long enough for me. I assume that isn't always the case, and would depend on where the controllers are mounted too.
Old 07-17-2017, 09:17 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
That's good to know. The innovate controller is built into the gauge so nothing else to find a place for other than the long cable.
I think I looped the innovate's extension cable length around in a circle under the passenger seat.
Old 07-17-2017, 10:09 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Have the PLX here too and love it... Doesn't require 2 oxygen sensors either... It has a output signal for your cars lambda system...
Old 07-18-2017, 04:32 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
kenikh's Avatar
This is what really turned more into the PLX. I can read the AFR and feed the ECU with one sensor. I also have mine under the driver's seat, as does another car I know.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-18-2017, 04:51 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Jeff NJ's Avatar
Mine is under the seat too.
Old 07-18-2017, 05:06 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Uncertifiable!!!
Uwon's Avatar
Boost gauge to replace clock - options?
Related thread you should look at.
Johan
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, A4 Quattro, Evolution of a Carrera RST.
Old 07-18-2017, 05:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
kenikh's Avatar
Johan
Good thread. If only I didn't have a VDO telltale...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-18-2017, 05:29 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Chain fence eating turbo
Innovate MTX-L
PLX
14Point7
AEM
There's a plethora to choose from
Old 07-18-2017, 06:12 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Old car guy.....
Hot Euro's Avatar
I went with Innovate a few years ago, started with the LM2 which allowed me to add map (boost) and fuel pressure to the standard air/fuel and rpm.
I added a separate board under the glove box. This helped me fine tune the old cis until usable.
I then parked the handheld on the console and added their A/F gauge in the console along with fuel pressure and volts.
I haven't used the hand heald since but it is there if I need to record a session. Innovate does not seem as easy as some other brands but maybe it's just way over my head in some areas. I need to go back and relearn some of this as I get the time.
81 SC Euro WB, 930/51 Turbo 3.0l Bored & Stroked to 3.2l, Ported Polished Twin Plug heads, Ruf IC, K27 7006, Powerhaus headers, Zork, 009 inj, Alum inj blks, 044 pump, BLwur, Mocal Oil cooler, LM2, 930 4 sp LSD, 930 Brembo brakes, Retroair a/c, Euromeisters.....
2003 BMW Z4 Daily Driver & Autocross car.
Old 07-19-2017, 04:43 AM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
