T77911S's Avatar
Originally Posted by quattrorunner View Post
The run into the chain boxes or oil plug don't require a pump but the line into the triangle of death area or the tank requires a pump.
yea I new the triangle of death needed the pump.
just another option for those that have the sump plate that don't want the hose that low to the ground.
I do like the idea of no pump and running it to the sump
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 08-02-2017, 04:44 AM
Uncertifiable!!!
Uwon's Avatar
The banjo is slick.
+1. Sure makes allot of "obvious" sense.
Johan
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, A4 Quattro, the RST hot rod-http://forums.pelicanparts.com/porsche-911-technical-forum/748639-evolution-carrera-rst.html
Old 08-02-2017, 09:27 AM
Uncertifiable!!!
Uwon's Avatar
For the banjo, is the thread size and pitch on a 3.2 case 22X1.5 ? (Oil already in car)
Johan
Old 08-03-2017, 04:08 AM
scottrx7tt's Avatar
Johan
Setrab susa ProLine M22-AN10 90* Banjo Connection - SET22-M22BJAN10-90 | eBay
1979 911SC widebody conversion. 3.1 engine, 3.2 liter heads, carrera intake, Microsquirt V3 ECU, K27 7200 High flow turbo, Tial F41 wastegate, Ford EDIS. .7 bar. 402hp 360tq
Old 08-03-2017, 05:35 AM
Turbo Powered Snow Blower
Originally Posted by scottrx7tt View Post
Heres what i did. Obviously, mine is a 3.0 with the sump plate, but you should be able to use it for your application also.
It is a banjo oil fitting from Setrab
This is so clean and simple. One more change just got added to my winter project list.
I can ditch the plumbing and pump system and eliminate the chance of particles being sent through the engine at the same time.
On the down side I already wasted money on a catch can and lines for the new GT35.
Derrick
Old 08-03-2017, 06:44 AM
T77911S's Avatar
so if you go this way and eliminate the need for the scav pump, can you put a set a stock SC cams in with no modifications?
Old 08-04-2017, 04:19 AM
^^^ Oooh. Good point. I would think the answer is yes.
Sent from my iPhone while Driving
Derrick
Old 08-04-2017, 05:59 AM
Brando
quattrorunner's Avatar
Of course. Just plug the drive accessories hole or seal it up some way. Or use it for clewett position sensor for efi?
Turbo powa!
1977 911s. it's cool
Old 08-04-2017, 08:00 AM
Uncertifiable!!!
Uwon's Avatar
Really like this setup.
How is the banjo bolt held in place on the hollow bolt? Circlip?
What section do you disassemble to drain the oil? Oil line connection to banjo? Unscrew hollow bolt? Or disassemble banjo from hollow bolt?
Johan
Old 08-04-2017, 07:19 PM
scottrx7tt's Avatar
Johan
Correct, the banjo is held in place with a circlip. When I change the oil, I just undo the turbo drain line from the turbo side and let it flow into the oil basin from there. I have been using this setup for a year and a half and about 6k miles with no problems whatsoever(except a shattered 2nd gear in my tranny)
Old 08-04-2017, 08:13 PM
Brando
I broke two 915 gearboxes. Traded up to 930
Turbo powa!
Old 08-04-2017, 10:37 PM
"Correct, the banjo is held in place with a circlip."
Really? How does the banjo seal with just a circlip? The link above for that fitting shows a standard hollow bolt and double sealing washer setup to clamp the banjo so it seals.
Old 08-05-2017, 08:38 AM
Gravity drain is the best set up, no question. Not sure why Porsche didn't go this route from the start, other than engineers like to sometimes over-complicate things.
Old 08-05-2017, 08:54 AM
Brando
I've heard of some with flow complaints and smoke as a result.
Turbo powa!
Old 08-05-2017, 09:16 AM
If the lines/fittings are too small I can see where that would be a problem.
Old 08-05-2017, 09:33 AM
I wonder if when a car sits long enough and the oil levels in the tank and sump equalizes the sump level could reach the height of the turbo shaft and start leaking into the compressor and turbine side of the turbo? Not at home right now to check it out. Maybe that is the reason why they used the scavenge pump setup?
Old 08-05-2017, 09:45 AM
scottrx7tt's Avatar
it is actually sealed with O rings. the banjo will swivel. I first tried a Mishimoto banjo that worked how you just described, but i got the thread size wrong. evidently, i linked the wrong part. Here is the correct one...
Setrab Banjo Fittings for M22x1.5 Ports 22-M22BJANXX
Old 08-05-2017, 11:19 AM
scottrx7tt's Avatar
That's a nice piece. Maybe I'll remove my pump and all the associated hardware and do this.
Old 08-05-2017, 11:57 AM
scottrx7tt's Avatar
You have a valid point there. Fortunately, I have never had an issue, but I try to drive my car on a pretty regular basis.
Old 08-05-2017, 12:23 PM
