Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Old car guy.....
Hot Euro's Avatar
Originally Posted by audiadj View Post
I just purchased this K&N filter; it did not work for me. First; it wouldn't fit until I trimmed the engine compartment foam sound mat and trimmed off a little of the K&N's rubber ID flange. Finally I actually squeezed it over the sensor plate and into position. When I began tightening down the large hose clamp it pulled part of the rubber ID flange away from sensor plate's rim towards the center of the sensor plate Venturi. The sensor plate ridge diameter is too shallow, any effort to clamp the rubber diameter around the sensor plate diameter will force it to roll over the sensor plate top diameter edge.
I would be worried if I actually got it to clamp; there's a very good chance it would not stay in position.
I had clearance problems with the k&n cone on my 3.0 SC. I picked up this used Mr. Gasket Deep-Dish Air Cleaner 6 1/2" Dia Round White Paper Element 4346 for about $20. Mounted a 0.5L Baffled Polished Aluminium Oil Catch Can With 19mm 3/4" Inlets + Drain Plug | eBay and ran the hoses to the center of the air cleaner. Some modifications are needed but I love the space this provides. No more need to remove the mailbox and intercooler for adjustments.
1981 SC Steel Widebody, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, 044 pump, BLwur, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters
2003 BMW Z4 Daily Driver & Autocross car.
Old 08-07-2017, 03:49 AM
Also, I had to put a notch ( a 'V' ) in the rubber base of the K&N Cone for the CO adjustment screw housing to sit straight up, as well as slide up and down easily.
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 08-07-2017, 05:02 AM
Picture of the notch:
Tim
1986 930
Old 08-07-2017, 05:11 AM
Capt Bob
Capt Bob's Avatar
That works...trim a little slot and there you go. Looks like a good fit.
Old 08-08-2017, 03:43 PM
