cdi and high rpm miss?
Can a cdi box cause a high rpm miss?
I'm still experiencing a slight high rpm (starts about 5,000) miss. Doesn't happen in 1st & 2nd, but it does in 3rd. The ignition set up is a 12 plug distributor, twin coils and twin cdi boxes. I've replaced the plugs, plug wires, cap & rotor and both coils. The only thing left are the cdi boxes. The a/f ratio is fine.
Old 08-05-2017, 07:50 AM
Alan L's Avatar
Have you matched injector flows? You may have a decent average AFR but still have a lean cylinder or two. At high revs, given what you have replaced, I would be looking there.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 08-05-2017, 04:44 PM
