Capt Bob
Capt Bob's Avatar
Turbo flange bolts
While out for a drive last night, one of my flange bolts connecting the exhaust to turbo charger inlet, either vibrated loose, or fractured and fell out on the road. I could hear the exhaust leak and loss of boost.
After things cooled down, I found the other bolts loose as well. I'm thinking of replacing all four.
I have looked thru the forum and have seen many different variations of these flange bolts.
Anyone have any recommendations? The photo attached is one that I removed to use as an example when I go to purchase new.
Old 08-16-2017, 05:31 AM
scottrx7tt's Avatar
The nuts should be copper lock nuts.
1979 911SC widebody conversion. 3.1 engine, 3.2 liter heads, carrera intake, Microsquirt V3 ECU, K27 7200 High flow turbo, Tial F41 wastegate, Ford EDIS. .7 bar. 402hp 360tq
Old 08-16-2017, 05:54 AM
scottrx7tt's Avatar
Old 08-16-2017, 05:58 AM
I've replaced all of the exhaust system bolts from the exhaust port studs to the last one on a muffler hanger with stainless on every car I've had and they worked... no problems... just perfect.
Also use ultra high temp nickel based anti seize on the bolt and nut threads because it's cheap, doesn't burn off, might take all of 60 seconds to apply, and always helps.
Old 08-16-2017, 09:31 AM
TurboKraft's Avatar
Fairman -- glad you found some of that nickel-based anti-seize, it is a huge help if you ever have to take exhaust fasteners apart again.
We only use stainless socket head cap screws (Allen head), M10x1.5x40mm.
Copper coated locknuts, with the added benefit of having a reduced hex wrench size.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 08-16-2017, 10:13 AM
Capt Bob
Capt Bob's Avatar
Stainless sounds like a plan. I have nickel-based anti-seize at home so I should be able to put it back together tonight.
No issues with the stainless and all the heat?
Old 08-16-2017, 10:48 AM
I found it at a local auto parts store. Looks like Amazon has it too.
I learned about it from you years ago.
https://www.amazon.com/Permatex-77124-Nickel-Anti-Seize-Lubricant/dp/B007NJOEAI?th=1
I've used the 12mm wrench size copper plated steel exhaust nuts too. The B&B header wrench for those nuts works good until it bends. To fix that I've used acetylene and oxygen torches and steel coat hangers to thicken up the part of the wrench that bends. Then dunk it in cold water while it's still red hot to make it stiffer.
The car is gone but I still have that wrench. B&B probably has them too. A combination open end and swivel socket wrench is also nice to have for those nuts.
Ken911's Avatar
Felpro n-7000 is about the best for high heat anti sieze. N-5000 is also pretty good. Both will also work with stainless steel.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 08-16-2017, 11:15 AM
