New Scavenge pump harden pin needed
I'm in the process of rebuilding my turbo oil scavenge pump and need to replace the hardened pin. I've found some pins online made out of 01 tool steel but not sure that's what I need or if I need to buy something different. Not my pump but here is a pic for reference.
Old 08-16-2017, 03:07 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hi Brian - if our members are not able to assist you with this; please feel free to give us a call at 888-280-7799 and one of our Porsche part specialists will be happy to help out with the part or recommend an alternative. Hope this helps a bit and best of luck!
Old 08-17-2017, 11:02 AM
jsveb's Avatar
Cole930 (RIP) used to kindly offer these.
In his absence I think a drill bit of proper diameter and cut to
length may work.
Cheers
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 08-17-2017, 12:03 PM
TurboKraft's Avatar
It is merely a metric dowel pin, nothing special.
If you cannot find one, then a roll pin will work just as well.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 08-17-2017, 02:29 PM
I used a drill bit. Works fine.
Old 08-17-2017, 03:48 PM
Great idea on the drill bit. I should have an old one I can use.
Thanks for the replies.
Old 08-18-2017, 01:45 PM
proffighter's Avatar
Not a good idea, to brittle. Should be more vicious, so they worn rather than break.
Look for bearing needles, they have the desired specs.
Roland
930 Turbo '81 Too many modifications to list
Old 08-23-2017, 04:09 AM
C'mon. Drill rod is perfectly fine. There is very little torque req'd to turn the scavenge pump. It's just a liquid mover, there is no discharge head to speak of besides the few inches in the tank.
If it locks up for some reason you want the pin to shear anyway.
Old 08-23-2017, 06:31 AM
