flat6pilot's Avatar
Flame out wastegate normal?
Hey guys- I was at a track event last Thursday and a few told me they could see a 'fireball' coming out the waste-gate. Although they thought this was cool, I wondered if it was abnormal. It was during deceleration only. My AFR's were about 16-18 at the time. It would come out the exhaust (zork tube only) too.
Is this normal, or is something wrong with the waste-gate?
-Kyle
* 1980 911SC - 3.0l R.o.W 8.6:1 w/ Garrett 30R turbo conversion (.5 bar), Bitz MS-II EFI, Carerra intake, Zork tube, 2300lbs, 360whp
Old 08-22-2017, 08:46 AM
Brando
quattrorunner's Avatar
Did you say 16-18 afr?! oh that's on dselcell...
Turbo powa!
1977 911s. it's cool
Old 08-22-2017, 09:35 AM
Crotchety Old Bastard
RarlyL8's Avatar
Your wastegate should be closed during deceleration.
Old 08-22-2017, 05:18 PM
T77911S's Avatar
does the WG empty next to the zork?
WG control line should goto manifold. if it is connected to the IC or above the TB then it would open when letting off the gas.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 08-23-2017, 05:02 AM
flat6pilot's Avatar
Right. I was wondering if there was an unusual scenario that would cause it to pop open under decel. I had the MBC turned all the way down (.3 bar) and I didn't notice any overboosting or lack of boost anywhere. Just seemed odd.
-Kyle
Old 08-23-2017, 09:09 AM
flat6pilot's Avatar
No, it opens out right after the WG (using the short 'screamer pipe'.)
I'll check the connection again, if I recall the boost signal comes from a tap on the charge pipe just before the IC. So that could cause it to act like a BOV? That won't harm anything will it? Do I need to re-do the plumbing and find a spot on the manifold?
-Kyle
Old 08-23-2017, 09:12 AM
'76 911S 3.0's Avatar
This is the correct method of hooking the plumbing up. The wastegate will not operate like a BOV in any configuration (unless the spring was broken) as the spring tension holds the valve shut until boost pressure overcomes that tension and opens the valve. If you are using a MBC, the line from the MBC should go to the bottom of the can of the WG and the top of the can should be open to atmospheric pressure.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 08-23-2017, 04:43 PM
RarlyL8's Avatar
Was the fireball quick or prolonged?
If the waste gate boost signal is taken from the intercooler (like OEM) then the waste gate will see boost spikes during snap shut throttle events. Those boost spikes will allow the waste gate to remain open for a microsecond until the recirculation valve opens and relieves the pressure above the throttle plate. This could allow a quick fireball out the waste gate pipe.
Old 08-23-2017, 06:57 PM
flat6pilot's Avatar
Yes, quick fireball. What you describe sounds like what it's doing. This was at the track going from high RPM to hard braking.
-Kyle
Old 08-23-2017, 08:01 PM
Roby466's Avatar
I thought everybody liked fireballs out the WG!
1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit
1981 Black 911sc (sold)
Old 08-24-2017, 12:42 PM
T77911S's Avatar
my mistake.
I was thinking of the BOV.!!!
my BOV is connected to the T on the TB'
yes, WG to IC
that will make it open when throttle is closed.
sorry for the brain fart
Old 08-25-2017, 05:09 AM
