Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Brando
quattrorunner's Avatar
Throttle plate flip
I'm trying to install a tps on a carrera throttle body which seems pretty simple however I can't seem to remove the linkage side in order to turn the shaft 180degrees.
Any ideas on how to remove this part? Seems to be pressed and sort of rivited on.
I've had it all apart ready to finish but just can't remove this part.
Turbo powa!
1977 911s. it's cool
Old 08-27-2017, 10:15 AM
dos531's Avatar
I think the throttle plate flip is only for the 930 tb. I tried when i converted to carrera manifold and it doesn't work. I ended up getting a new tps and adapter from turbokraft.
Sent from my SM-G950U using Tapatalk
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'01 996tt
Ducati 748R
Old 08-27-2017, 01:33 PM
Brando
Hmm. Well that would be great if the tps just installed into the carrera tb.
But clewett instructions say carrera and 930.
Turbo powa!
Old 08-27-2017, 01:36 PM
What is on the other end of that shaft? Is there a nut securing the shaft through the throttle body? In my mind, I have to think that shaft must come out in the direction you are looking at. I do not see how that shaft could be pressed in and then that fitting pressed on after it is installed. So, I would look on the other side to see if there is something to loosen that will then allow the shaft to slide out with that fitting still attached as shown. Sorry, I do not have a Carrera assembly to look at for reference.
I know it is different, but here is a link with pictures for a 930 throttle body flip procedure, in case it gives you some ideas.
http://www.clewett.com/instrux/930%20EFI%20Instructions.pdf
Emery
1988 930 coupe - Silver Metallic
stock 3.3L w/GT35R, B&B Headers, RarlyL8 muffler, B&B intercooler, Tial wastegate, Electromotive tecGT based phased sequential EFI & ignition, Wevo shifter
Old 08-27-2017, 03:05 PM
Brando
Sorry for. It being clear.
I have already had the shaft out because the other side does allow that. It only has a clip holding it in that side. But this side I need to remove this side so that I can turn it 180*
Turbo powa!
Old 08-27-2017, 03:35 PM
Brando
I ended up doing a bit of cutting of the ends of the flared end in order to allow it to come off the end. Having done that it was easy to remove and turn it around 180*. While in there I rebushed a part of the linkage. The linkage moved enough that the throttle closed switch/sensor wasn't adjustable any longer. Now it is. Here is the end result before I install tonight.
Turbo powa!
Old 08-28-2017, 02:14 PM
TurboKraft's Avatar
You know we make a bolt-on TPS kit for that, right? Don't have to disassemble the t-body or anything, just remove the 5-pin switch and replace with the new adapter and sealed 3-pin TPS.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 08-28-2017, 08:02 PM
Brando
After doing this it doesn't even look like I really needed to flip it with this part either.
Turbo powa!
Old 08-28-2017, 08:40 PM
ELZ's930's Avatar
Funny we always find out those things after the fact.
the911den.com
Instagram / UberPorsche930
Old 08-29-2017, 05:56 AM
gavinc69's Avatar
I used a TurboKraft TPS and adapter kit on my 3.2 TB, went on in about 5mins. Easy and perfect fit.
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, MSD 6AL, Blaster Coil, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, OE Short Sift, K27 7200 Turbo Conversion, OBX Headers, Tial Wastegate, EFI MicroSquirt v3
Old 08-29-2017, 10:24 AM
Strygaldwir's Avatar
It seems Clewett suggested flipping it to gain clearance for TPS. It seems the WUR would be somewhat in the way. I found when I flipped it that I could not easily get at the sensor connector. The support for the intercooler was in the way. I put the butterfly valve back in the original orientation and there appears to be no issue with it.
I did use Turbokraft's TPS mounting kit. Worked great!
Old 09-20-2017, 02:34 PM
Brando
No need for wur if you need tps.
Turbo powa!
Old 09-20-2017, 03:01 PM
Yes, no WUR needed with EFI.
Old 09-20-2017, 03:47 PM
