camdon's Avatar
Originally Posted by 911nut View Post
+1 on Jim.
Very skilled guy and great to work with.
Jim never replied
A few P-cars in the garage
Old 09-19-2017, 12:36 PM
Metal Guru
911nut's Avatar
Originally Posted by camdon View Post
Jim never replied
I just sent him an email with the link to this thread.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 09-20-2017, 05:16 AM
camdon's Avatar
Thanks Paul
I think I am going another direction. What do you guys think these are worth? I told the seller I would ask around for him.
Old 09-20-2017, 05:18 AM
Metal Guru
911nut's Avatar
Originally Posted by JFairman View Post
I also have unpleasant expensive experience with Jim Dorociak...
He sprayed some kind of lousy BS puff can clear coat on them and it did not work. The aluminum quickly corroded under the crappy thin clear he sprayed on and looked like sh_t.
What really pissed me off is he acted like a pathetic prima donna and would not tell me what he sprayed on them.
To strip the crap he sprayed on them off so you can repolish the wheels they have to be completely taken apart and aviation paint remover is needed to get the BS Dorociak sprayed on them off. That was years ago and I hope he's done with ripping people off by now.
He refinished my wheels 10 years ago and they still look great.
Paul B.
'91 964 Turbo
Old 09-20-2017, 05:20 AM
JFairman - Jim my last email that I can find from you was when I originally sold you new 4.75" RH outer rim halves was 6 - 30 - 2009. As I remember back 8 years ago I even bought (2) RH used rim halves from you after helping you resize your own wheels that you did the assembly on. Yes I did not tell you the exact name of the special clear coat used. I consider it a trade secret. I am shocked to hear about your unpleasant experience with me. jdorociak@gmail.com Jim
Old 09-20-2017, 06:03 AM
Can they be restored? Sure, but are they the right size for the car you are thinking about putting them on? Many times a resizing is needed or wanted such as I want an 11" vs a 10" and I am going to remove the rear spacer as Jim did on his 930 years ago when he resized his rear wheels.
So to really understand what it takes to restore a set of wheels first is do they fit correctly, if not what sizes are needed or wanted for the "look" . Next is verification that the set is straight/true and round. It does not make sense to restore a set of bent wheels. I have seen because of the age of the sets and the condition of the roads the cars are being driven on many sets that now require inner and outer rims need to be replaced so at this point it gets expensive and difficult to locate parts for special builds.
The set you are asking about is the Alessio wheels, which are not the most sought after Speedlines.
The center caps alone cost about $100 each and are most difficult to find (unique to this set of wheels)
So what car are these going to go on? What size do you want? What kind of finish do you want on the set?
When I build sets of Alessio wheels for Porsche friends they are priced in the $4100 range and up depending on sizes and finishes. I have found in the end it is cheaper to buy a restored, resized set vs buying a cheap set and the cost to build/refinish that set. Good luck. Jim jdorociak@gmail.com
Old 09-20-2017, 07:35 AM
Thanks Paul
I would be willing to take a look and make a reasonable offer.
FWIW these wheels can be bought new for $3400/set.
Cheers,
Patrick
'78 930 #441
'87 951
Old 09-20-2017, 12:43 PM
camdon's Avatar
PM me your number
Old 09-20-2017, 01:16 PM
