Bosch CTS
What is the part number for this sensor? Mine is gone wonky...
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 09-22-2017, 01:44 PM
OK, found it...
311 906 041 A
now to find one close by...
Old 09-22-2017, 04:09 PM
cylinder head temp
What are you EFI guys using for head temps? I'm using this Bosch 1 wire sender on head #1. It quit yesterday while out on a drive, 2 hrs from home, had to limp back running super rich. Anyone have luck with the 2 wire Bosch ?
Old 09-23-2017, 06:19 AM
proffighter's Avatar
Using 1 wire got with the SDS EFI
Roland
930 Turbo '81 Too many modifications to list
Old 09-25-2017, 04:21 AM
TurboKraft's Avatar
We've been using the 2-wire Bosch exclusively. Zero failures. Tracks temps very accurately.
https://parts.turbokraft.com/products/cylinder-head-temperature-sensor-set
Installed
Similar placement as factory 3.2 Carrera and 964/993, only no head machining required.
Easy to install. Check your measurements before cutting the opening in the #3 cylinder tin as there's slight variations in castings.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 09-25-2017, 11:27 AM
Chris, I think you have a better location for the sensor, I have mine on cylinder head #1. Installing the temp sensor under the fan shroud subjects the sensor to too many different conditions, such as idle/heat soak, and cold weather conditions that we suffer from in Canada, which makes it very hard to adjust the ECU to have good AFR's across the heat ranges. I think I'm going to swap to your location...
Old 09-25-2017, 05:48 PM
TurboKraft's Avatar
Yes, I can see that being swayed by ambient air temp based on where you have it located.
We checked this installation's readings against readings from sensors threaded directly into the head as per factory, and it tracks perfectly.
And since many customers are converting to EFI *after* their engine is already assembled, this method of mounting allows them to install a CHT sensor without any major engine disassembly for head machining.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 09-25-2017, 06:08 PM
Turbonut
Raceboy's Avatar
I machined thread for CHT into a cylinder head, bought 1 wire Bosch unit and soldered a ground wire in addition so that the readings are not distorted by ground issues.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 09-26-2017, 12:45 PM
