Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
jopo911's Avatar
Turbo boost gauge going crazy
My 1986 930 OEM boost gauge suddenly started going crazy. Jumps all over the place. Turbo is working properly, AFR gauge normal. Any clues what might cause this?
1986 Black on black 930
Kokeln IC/ 1 bar spring/European Fuel Head
GHL Exhaust Dual Exhaust, Wevo shifter and coupler
935 Front Air Dam, Forgeline wheels
Old 09-28-2017, 02:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Dmitry at Pelican Parts's Avatar
Hi Joe - take a look at the link below to earlier threads that discuss this issue. Hope you find it helpful.
930 boost gauge problem
Need a little help with boost gauge
Old 09-28-2017, 02:51 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
mark houghton's Avatar
Those are good articles. At the very least check the hot and ground connection to the sending unit back on the engine (orange or faded red) rubber covered thing beneath the IC
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 09-28-2017, 05:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Alan L's Avatar
If you have a nil connection, the gauge is pegged. So an intermittent bad connection will give you everything in between.
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 09-28-2017, 11:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
