No start, No click
Very frustrating situation. Engine started last week after replacing a battery that went dead on a trickle charge in storage. Next day I turned the key and "nothing." Dash and lights work fine, Battery putting out 12.8 volts. No Click, no turnover, and No start.
Ignition bad? Wires? or Starter? |
See if the positive lead to the starter is tight. And, make sure your battery is grounded and make sure it is grounded back by the starter.
Iceman: Thank you! That is precisely what it was
CLEAN the connections, all major power ones.
put meter on battery while cranking. if less than 10v batt is bad |
| All times are GMT -8. The time now is 12:10 AM. |
