How's your build coming Phillip?
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 57lbs. Cobra Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 11-26-2017, 07:19 AM
Hey John, have just about all the parts needed now... Will start when I get back from the DR in Feb. I'll start another "MY BUILD" thread then... Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 11-26-2017, 08:36 AM
Originally Posted by Oheggem View Post
Ah ok. Will see if i can get some. Used carparts prices in Norway are rediculous. Hope you document the install so i can get some tips from
Here's a pic of both part numbers for the COP's that you can use... they come on early 2000 Toyota V6's. There are loads of these cars in the auto salvage yards here. Philip
Old 11-26-2017, 11:38 AM
Oheggem's Avatar
thx! Been looking at online breakers and those coils are about $50-80 each. Hurts my budget
Porsche 930 `79 #973
Old 11-26-2017, 11:48 AM
dos531's Avatar
I am using the audi 1.8t coils on mine. They were about $20 each I believe.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'01 996tt
Ducati 748R
Old 11-26-2017, 12:30 PM
They sell after market ones in the US for under $10 each...
https://www.ebay.com/itm/CAMRY-SiENNA-AVALON-HIGHLANDER-ES300-RX300-IGNITION-COIL-UF267T-90919-02234/172818000238?hash=item283cc1696e:g:iZ8AAOSwB09YD7O P#shpCntId
Shipped world wide... don't know how much to ship your way... Philip
Old 11-26-2017, 12:31 PM
Oheggem's Avatar
Before i decide i had a thought. I got Electromotive dfu coils and not sure how i will wire them to the MS. Dfus have 12v, ground and a triggering wire. On the ms manual it says use soark a to coil negative etc. So ground the dfu through ms? Or the trigger. Using quadspark module also. Do want to use what i got if i can. Those aftermarkets are really cheap. Wow
Old 11-26-2017, 01:13 PM
Oheggem's Avatar
Think i found the DFU answer but i had another. I see others cutting their recycle valve housing and jb weld it closed. I saw one leaving the overboost switch. Do i need that?
Old 11-29-2017, 11:39 AM
dos531's Avatar
You do not need the overboost switch. Overboost protection is handled by the ECU.
'01 996tt
Ducati 748R
Old 11-29-2017, 11:44 AM
Oheggem's Avatar
cool thx. i`ll just cut right after it. starting to have it all figured out now. found out i need to cut the pancake manifold a little on number 6 to allow the fuelrail mount. The mounting hole on the injector block is covered. Small thing but things like this keeps stopping the progress. oh well
Will be back with more exiting stuff and pics later. Work again tomorrow.
Old 11-29-2017, 12:10 PM
TurboKraft's Avatar
Cut the manifold?? What system are you installing?
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 11-29-2017, 12:18 PM
Oheggem's Avatar
GSF. I shouldn`ve taken a photo oof it but on cylinder 6 the edge of the intake manifold just covers the threaded hole to mount the fuelrail. Like the TPS mount, i think i got a kit suited for a later 930.
Old 11-29-2017, 01:51 PM
Can you upload pic of manifold at number 6?
Old 11-29-2017, 05:49 PM
Oheggem's Avatar
Im at work now (truckdriver) but ithink wednesday i will go at it again. Got stuff together now so is exiting 👍😜
Old 12-02-2017, 10:44 AM
Any update on conversion?
Old 12-27-2017, 06:12 AM
Oheggem's Avatar
Waiting for some parts along with lots of work and christmas so not much done. Decided to go TK for tos kit and cobsidering doing that with CHT as im not finding an easier sollution that works. After new years i will hopefully start again 🤡
Merry christmas 🎅🏾
Old 12-27-2017, 09:42 AM
Oheggem's Avatar
So moving foreard with more parts. Got a 044 fuelpump an did most of the wiring.
Can i use this ivc Bosch nr, 0 280 140 501? I can get it locally.
Anyway, slow moving but moving��
Old 10-04-2018, 05:42 AM
