LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.50 average.
motor apart
Chris very nice setup....basically that is what I am looking to do and very similar. Like the intercooler.... joys of removing headstuds this weekend and separating the block
Old 11-01-2017, 07:00 AM
can you count the broken headstuds? Motor only has 33k on it
Old 11-01-2017, 07:01 AM
Strygaldwir's Avatar
As to sources for your build:
www.diyautotune.com/ They have a lot of the connectors and sensors for EFI. They mostly support the megasquirt ECU, but many will be usable by TEC
Clewett Engineering, The complete solution for ignition & fuel injection has the the serpentine kits. Not certain I'd go through the expense if I did not have air conditioning. They also have the crank pulleys, crank sensor holder, plug for the distributor.
Turbo Kraft Porsche Parts and Custom Builds | Porsche Service Arizona has an outstanding kit for the fuel rails and injector mounting. Chris is always heaps of help!
Len Cummings (len.cummings@verizon.net) is an excellant source for fuel lines you'll need for the conversion. He is also a pelicanite and can be reached here.
Dennis (powellgillam@hotmail.com) is another Pelicanite that makes engine wiring harnesses. He can custom build pretty much anything you might need and is another great guy to work with.
You may have already reached out to some of the above sources, but I have found them all to be great to work with to make your EFI conversion.
Good luck,
Keith
Old 11-01-2017, 05:30 PM
TurboKraft's Avatar
Thanks!
IMO a serpentine belt conversion is completely unnecessary. If your pulleys are good, and the belt tension correct, these don't throw belts.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 11-02-2017, 10:32 AM
Good to know Chris.... running Carrera 3.2 intake Chris can I use the factory rails or should I change them?
Old 11-02-2017, 05:00 PM
Originally Posted by TurboKraft View Post
Intercooler & exhaust.
The intercooler fits within a standard factory rear wing.
Who makes the inter Cooler?
Old 11-02-2017, 05:03 PM
Kartoffelkopf
Spenny_b's Avatar
Stock should be fine fed with -8AN hoses. Running them on my build; the only comment I would add is that we dont have much E85 here in the UK, just Super Unleaded 99RON - not sure what the flow requirements of E85 are (apart from it being higher than SUL)
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 11-02-2017, 05:31 PM
Info
Good luck,
Keith
Thanks for the info!!!! All info is appreciated
Harry
Old 11-02-2017, 05:41 PM
Thanks saves me hunting down rails!! Money saved =)
Old 11-02-2017, 05:49 PM
3 restos WIP = psycho
kenikh's Avatar
Turbokraft rails are like jewelry. They're the best on the planet.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-02-2017, 06:53 PM
injection rails
Thank goodness I don't need the dress up!! I like them but trying to stay within the budget on this one.
Old 11-03-2017, 06:57 AM
Chain fence eating turbo
Stock 3.2 fuel rails will flow more than just about anyone can make power on.
Old 11-03-2017, 07:06 AM
kenikh's Avatar
I didn't notice any price difference between the turboKraft rails and anybody else's. They're just better.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-03-2017, 07:58 AM
