-   -   Turbo build (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/973951-turbo-build.html)
xtturbox 10-14-2017 02:35 PM
Turbo build
new parts list...
Started my shopping list and have purchased a few items....if anyone has recommendations of where to buy or have anything in the list for sale I would be very interested!! I am going Twin Turbo EFI Twin Plug
Compression still to be determined =8.0:1 or 8.5:1
Crank trigger, Serpentine belt conversion
Bosch IAC with 2 wire conversion
Map Sensor 2 or 3 BAR
MAT Sensor
Cam Trigger
TPS (TBD)
EGT
WideBand o2
Knock Sensor Kit
Bar plate for Knock Sensor Kit
APR Head Stud Kit
Exhaust
Gasket Kit, Oil Lines, Plugs, Misc
Carrera Intake 3.2
Pistons and Rings
EFI, Ignition (Tech3r )
Cam Chain Tensioner Kit
Fuel Rail (TBD)
Injectors (TBD)
Injector Harness
A-N Fuel Lines, Misc Fittings
Machine Shop (have)
Upgraded Valves, Springs, Seals
Turbos (Have)
Exhaust work
Intercooler, piping, fittings
kenikh 10-14-2017 02:39 PM
Youíre going to want at least 964 cams with that compression, but Iíd recommend 993 super sport. Thatís what I have in my 8.3:1 twin plug turbo motor.
Sent from my iPhone using Tapatalk Pro
Tippy 10-14-2017 03:36 PM
Since you're already going to use a Carrera 3.2 intake, you can use a plethora of TPS with a custom adapter. I'm using a mid '90's 325 TPS. All early to mid-'90's BMW's except the 318 fit the square D shaft.
2nd, the fuel rails on the 3.2 flow well enough for our motors. No need to upgrade.
I like my 80lb/875cc high-Z Siemens Deka injectors. ID1000 or bigger (if big hp E85) would be even better in idle quality. Mine idles just fine for me with the Dekas.
xtturbox 10-14-2017 04:24 PM
Thank you....wasn't sure about cams as I've seen the sc's are pretty aggressive for turbo applications but I have looking at 964 too
Yes analog run gas no E85 for me but was wondering what most are running for injectors. I like the idea of 80# too much more I think idling will be a big issue on the street
Tippy 10-14-2017 04:30 PM
With ID injectors, idling is never an issue if your EFI system has granular enough injectot PW resolution.
kenikh 10-14-2017 05:00 PM
SCs are about as UNaggressive as you can get. Even 993SS purr like a kitten on my high compression 3.4 running CIS. With that high of static compression, youíre going to want a cam that eases up dynamic compression. Trust me, 993SS is the way to go. They only get a bad rep from those who have not used them. If I had it to do over again, Iíd even go more aggressive with GT2s.
xtturbox 10-14-2017 05:27 PM
Yeah but I'm not running high compression I'm running either 8.0:1 or 8:5:1. Which hasn't been determined yet as I'm waiting on some data
kenikh 10-14-2017 05:33 PM
8.5 is HUGE compression for an air cooled 911 turbo without knock control. Even a 993 turbo only ran 9.2:1. These cars arenít Evo Xs or STIs. You need to design the engine correctly or youíll melt something.
xtturbox 10-14-2017 05:35 PM
Yes but I'm going to be running knock control... clewitt has a great system
kenikh 10-14-2017 05:38 PM
So am I. Just leave some margin, is all. Cam choice is critical or your dynamic compression is going to plasma cut you a paper weight.
xtturbox 10-14-2017 05:42 PM
That's what I'm working on now....Cams and compression, but should have it figured out pretty quickly plus running tech3r with full timing map control
kenikh 10-14-2017 05:42 PM
xtturbo, you sound like a Subie guy. Forester XT? I have a 22b replica motor I need to unload. :)
xtturbox 10-14-2017 05:43 PM
Looking for as much input as possible here from people's experience. It's a **** ton on money to grenade a motor
xtturbox 10-14-2017 05:46 PM
Way before that time....started with Subaru xt's in early 90's then wrx 2002 which couldn't make fast enough so built a 2006 3.2 stroked evo many moons ago
kenikh 10-14-2017 05:46 PM
PM me RE: Tec3r. Iíve spent 2 years with a Tec3r and can share some thoughts.
And Iíve calculated every permutation possible on static to dynamic compression and cam, including boost compensation in the dynamic number.
xtturbox 10-14-2017 05:47 PM
I will gratefully take any advice you have =)
kenikh 10-14-2017 05:49 PM
I'll save you a ton of time and money. I've redone everything twice. [emoji24]
xtturbox 10-14-2017 05:53 PM
Thank you!!!!
dap930 10-15-2017 09:13 AM
kenikh,
Did you have to fly cut valve pockets in the piston tops to use 993SS cams?
kenikh 10-15-2017 09:32 AM
Originally Posted by dap930 (Post 9777021)
kenikh,
No. JEs cleared no problem.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
