84 turbo, federalize with a unknown WUR
Car came to me not running for last 3 years.
It did run but got less dependable before parking it.
Aftermarket CD box with prematune innards and matching coil, but not a 001,
I jumped both relays to get the pumps running but non start.
Removed the jumpers on the relays and got the 5 second burn off with some ignition afterward.
So, too much fuel in the system.
Possibly the fuel distributor pin is frozen in the up position.
OR the WUR, which I have never seen the likes of, is the problem
Can I get help with the identifying and possibly how it works, pictures below
Help and Imput is appreciated, thank you
Bruce
Old 10-23-2017, 12:16 PM
dos531's Avatar
Some sort of electronic wur it looks like? Where does that plug go?
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'01 996tt
Ducati 748R
Old 10-23-2017, 02:10 PM
Alan L's Avatar
Looks like one of the UT Digi WURs? That may be your problem. Suggest you swap the WUR out.You won't get much help from UT.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 10-23-2017, 02:34 PM
T77911S's Avatar
what are the fuel pressures?
did it flood the engine?
is there a vacuum hose from the control box to the TB?
I think I would dump it and get a regular WUR
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 10-24-2017, 03:04 AM
Crotchety Old Bastard
RarlyL8's Avatar
A quick search on the UT gizmo will give insight into that silver box. There was a thread some time back that chronicled all the difficulties they were having. Quick fix as others have stated is to swap it out for a standard WUR. You may need to adjust the mixture if it has been manipulated to work with the UT unit. If still dumping fuel then look at the FD.
Old 10-24-2017, 03:34 AM
Alan L's Avatar
You cannot tweek the Digi WUR settings without a download programme from UT. You hook your laptop into the black box (There should be a USB connection coming from it.) It also has to splice into the purple/black TD wire for rpm. It looks like a Gen 2 unit. They used a fuel injector duty cycle tweek to control the WUR control pressure. The injector was doing the same job as the diaphragm in the regular WUR. Tweek the duty cycle and you altered the fuel pressure on top of the FD piston. The injector controlled the flow back to the fuel tank. But as far as I know they never worked properly. Mine didn't. Dump it or you will be spending a huge amount of time chasing shadows. Everything should retro fit back to a regular WUR. You will have a spare TD wire to dispose of.
Regards
Alan
Old 10-24-2017, 09:47 AM
I ve been on the search for the proper WUR, got 3 numbers that work and a lead to one.
As I was thinking, replace after imput.
Thanks,
Bruce
Old 11-05-2017, 03:45 AM
RarlyL8's Avatar
WUR for a Euro 1984 930 would end in -112.
Old 11-05-2017, 06:53 AM
T77911S's Avatar
i cant keep the numbers straight, but get the USA one, it is a better one to make adjustable.
Old 11-06-2017, 02:44 AM
RarlyL8's Avatar
All can be made adjustable except the early 3.0L 930 units. I run a modified -112 WUR on my 1985 Euro 930. Most commonly found (in the US) is the USA -153. It makes no difference what the part number is once the modification is complete because you can then put the settings wherever you want them (which is both good and bad). We also have made 930 WURs out of 911 WURs, fully adjustable. All you need is the correct housing.
Old 11-06-2017, 03:34 AM
T77911S's Avatar
the 054 is the bad one. I cant adjust boost or threshold settings.
I would like to drop my boost about .2 bar.
mine has one adjustment in the bottom and it adjusts the WCP and boost pressure together and one adjustment for CCP.
brian I got this WUR form you. if it can be made to adjust boost separately then we need to talk.
Old 11-07-2017, 03:02 AM
RarlyL8's Avatar
There are 2 versions of the -054, early and late. The early version lacks the ability to adjust threshold, both versions can adjust boost. Yes glad to help if the unit isn't working correctly.
Old 11-07-2017, 03:37 AM
T77911S's Avatar
pm'd you
Old 11-07-2017, 08:24 AM
hwfjim's Avatar
Thanks Bruce and All for your help and input.
1927 Ford T-Bucket
1956 Nomad
1984 Porsche 930
1996 Impala SS
Old 11-09-2017, 11:13 AM
