Originally Posted by Ken911 View Post
It should be pretty stiff
So if its pretty stiff meaning you cant pinch it , its like a solid tubing ?
Hi T77911s ,
Ive not tried squeezing it yet . But I doubt if I can squeeze it close w/ one hand
Luigi
Old 11-05-2017, 04:29 AM
Hi Guys ,
An update . I visited my old mechanic whose already retired due to renal failure. I consulted him regarding loosing power at high speeds. He advised me to replace the spark plugs . Good thing I still had the NGK BP8ES I brought 2013 from PelicanParts . I also tried to tighten / grip of the Wutrin red round relay thats made in China , the pair that supplies the fuel pumps. I also replaced the 25 amp fuse of the fuel pumps. I tightened the screws of the terminal blocks that holds the wire/ fuses . The son of my old mechanic arrived and he replaced all spark plugs using the Porsche special tool w/c made the job easy for him. He said w/o that tool he would have hard time . He examine the old plugs ( Bosch Super W5 ) and he noted the 5 plugs has a lean mixture burn , while the other one from the left bank had a bad sooth and looks like its on its way out. I have not replaced the spark plugs since I bought the car in 2008 . But I change the engine oil and brake fluids annually and the gear oil every other year .
We tested the car in the freeway and it easily hit 110 MPH w/o loosing power nor stumble / stutter . It seems we have solved the problem but , the mechanic is dropping by today to check the burn characterictics of the NGK plugs . If its still lean we plan to adjust the CO . Whats the normal CO for a stock 89 911 turbo .
Thanks in advance ,
tdh888
Old 11-14-2017, 05:01 PM
Nothing say love like a fresh set of spark plugs.
Speaking of which I need to change mine soon.
Old 11-15-2017, 05:35 AM
Hi slow& rusty ,
Its been quite sometime since Iíve replaced the spark plug of my BMW & F Car , it really makes a difference if one install a fresh set of spark plugs
Tdh888
Old 11-17-2017, 12:44 PM
T77911S's Avatar
yea, cap and rotor will help too.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 11-20-2017, 03:09 AM
If you have boost but are loosing power, sounds like a fuel starvation issue. You would hear or feel a missing cylinder if it was ignition.
1978 Porsche 930
1968 Porsche 911S
1964 356C
Old 11-20-2017, 04:10 AM
Hi ,
T77911S , Iíve not replaced the rotor yet , I will order one from our sponsor.
I agree w/ you Ficke , thatís why Iím asking myself if it was the new spark plugs or my tightening / securing the 2 relays & 25 amp fuse of the fuel pump w/c solve the problem
tdh888
Old 11-20-2017, 05:42 PM
Originally Posted by TDH888 View Post
Hi ,
tdh888
relays/fuses either work or they don't..
Cheers,
Patrick
'78 930 #441
'87 951
Old 11-20-2017, 05:53 PM
