930 1986 only starts with air meter plate pushed down
Can't start unless plate pushed down and won't continue runninh
Old 11-02-2017, 07:00 PM
3 restos WIP = psycho
kenikh's Avatar
Bad accumulator or one of the two check valves need replacing.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-02-2017, 08:06 PM
lite75's Avatar
just cold or when warmed up to?
75 930, 76 930, 83 SC EFI turbo
Old 11-03-2017, 06:57 AM
Can't keep it running- will try to warm it up by keeping the plate depressed
Old 11-03-2017, 07:16 AM
kenikh's Avatar
Sounds like an accumulator. Just went thru this in my wife's SC.
It would kick over from the cold fuel valve, but would die shortly thereafter. If I to ran the back of the car while it was still sputtering and tickled the air plate it would idle (poorly) for a while then die. I could keep it running using starter fluid. After a few minutes, if I played with the plate and throttle linkage, I could get it to idle fine, and even get it to hold RPM.
In the end, I used starter fluid and the above technique to get the car warmed up to operating temp. Once at operating temp, it ran fine. That's when I drove it straight to my mechanic.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-03-2017, 07:42 AM
T77911S's Avatar
not likely the ACC. if it wont stay running.
you already have another thread on this. limit it to just one .
I would suggest the other one since you have more info
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 11-03-2017, 10:15 AM
kenikh's Avatar
Interesting. Mine wouldn't stay running and it was the ACC. Where's the real thread?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-03-2017, 11:52 AM
