Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Many opinions on 1986 930 no start
Sat 3-4 weeks.Started right up. Ran for 1/2 block-stalled. 15 minutes later , started up. Drove 1/2 mile to gas station but tank full and only added 2 gallons fuel.Drove 2 blocks and stalled again. Towed home. New Bosch CDI box and yellow overboost relay. Pumps run great and hear gas squirting through injectors when air meter plate depressed . Starts for 2 seconds with Starting fluid into intake. Starts and runs while air meter plate slightly depressed but stalls when released. Opinions so far: fuel accumulator, warm up regulator WUR, frequency valve , cold start injector ,-don't want to start replacing all components. Has anyone seen this problem or has a solution?
Old 11-03-2017, 06:02 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
T77911S's Avatar
does it start right back up or does it have to sit for a while?
if it has to sit and the CD is new I would look at the coil.
when it will not start check for spark.
if no spark verify either CD is whining or it has power
if holding the metering plate down KEEPS it running I would check to see:
if the FV is vibrating
air leaks
remove the connector from the top rear of the AFM. this will run the pumps all the time when the key is on. when I cuts off, verify both pumps are running. (could be the speed relay under the seat)
check control pressures.
check for 12v at connector of WUR. measure between the 2 pins
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ [__] RUNNING: [__] NOT RUNNING:
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[] RUNNING:[_] NOT RUNNING:__2000 MER E320 WAGON [_] WRECKED:[]RUNNING:
Old 11-03-2017, 09:23 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
did you mess with co adjustment? if so you might readjust the screw until the plate just begins to open up
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 11-03-2017, 03:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Did not touch CO adjustment,pumps run all the time- overturn safety removed, won't start no matter what unless ether into intake or plate depressed-must be a no fuel issue with full gas tank
Old 11-04-2017, 07:21 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Sorry to hear about your starting and running issue. I had the very same thing on my 86. Went through just about everything (including rebuilding twin CDIs, replacing coils, wires, WUR, ...) In the end, as strange as it may sound, the battery was bad. I replaced the battery and it's run great ever since.
Sometimes it's the inobvious.
Old 11-04-2017, 08:18 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Ken911's Avatar
If you read the no start thread above, it's very comprehensive. Very helpful and lots of tips on troubleshooting
Old 11-04-2017, 08:53 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
T77911S's Avatar
Check Fv for vibrating
Control pressure
Check fuel flow. You can do flow to WUR
Old 11-04-2017, 12:22 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
