tops911's Avatar
the factory tool is the only way to go. I used NKG plugs once, which have are 5/8" hex and changing them out made me go back to Bosch and the 13/16" and the factory tool. I had to use a 5/8th spark plug socket with the swivel but i had to tape it up to take the slop out of the swivel and i really could not get the extension to the right length to make it as simple as the factory tool
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, MSD 6, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 11-08-2017, 06:58 PM
I did this with my local 930 bud on his 87 and found, that like on my 82 SC, the best tool is an old school pressed metal plug socket snagged from a 70's BMW tool kit. Easier for me than the 911/Klein plug tool. John.
Old 11-08-2017, 08:22 PM
Boost Abuser
LOWFAT's Avatar
Factory tool, and have to remove waste gate for bottom row on my twin plug motor. No emissions, or air box and remove IC. Takes me about 45 minutes start to finish.
"I can't drive 55"
Old 11-08-2017, 10:05 PM
T77911S's Avatar
Originally Posted by Strygaldwir View Post
I use a spark plug socket with an extension JB Welded to the socket. This lets me pull the socket from the plug without pulling the extension off. It make the whole process a LOT easier.
Keith
I use basically the same thing. but I actually welded it all together.
I also have the factory tool, I prefer mine.
not sure what all you have on your engine that is in your way.
#1 is the hard one for me.
I have also done compression, leakdown and just recently put a colortune in all 6 to check mixture. going to do it again.
yea I get a little scratched on the left side. I could make it easier if I tool the IC off.
getting lazy(ier)
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 11-09-2017, 04:02 AM
The tough one was #3. It hides under the paper heater tube. I was afraid I would lose the plug in the hole, or not be able to get the new plug started and wind up pulling the engine.
Now that the CV joints boots are failing, I might pull it anyway.
1986 911 turbo - less than 30k miles
Old 11-09-2017, 04:10 AM
T77911S's Avatar
does you sparkplug socket have foam inside to hold the plug?
also why I welded my socket, swivel and extension together.
Old 11-09-2017, 04:25 AM
Ken911's Avatar
I use the engine drop method. Jack up the car, remove the tires, remove the rear engine mount bolts, lower the engine a few inches and they are easy to get to.
Old 11-09-2017, 04:56 AM
I have to take the intercooler off for the 6 plugs on top, jack up and the wheels off for the 6 plugs on the bottom.
but I have noticed as I get older my patience is getting less. Not a bad job but I plan for at least an hour or more to do it.
1978 Porsche 930
1977 911S Targa
1975 911S Coupe
1968 Porsche 911S
1964 356C
Old 11-09-2017, 05:09 AM
I just remove the car from the engine....
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 11-09-2017, 06:10 AM
Crotchety Old Bastard
RarlyL8's Avatar
Changed plugs again on a Euro 930. These are the only tools you need to do the job. It helps to have the plug socket pinned so the adapter doesn't pull out when putting in the new plugs.
Old 11-09-2017, 08:16 PM
3 restos WIP = psycho
kenikh's Avatar
Must not invoke images of Rawknees changing his "plug" in his 930.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-09-2017, 09:19 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
That image is forever in the forefront of your kinky mind, Kenik La' Freak!
Old 11-10-2017, 12:14 AM
SBK930's Avatar
Originally Posted by Alan L View Post
Can someone post a pic of their favourite plug tool? I don't know what the factory one looks like, but I am sure I can improve on what I do now - two different extension lengths on a regular plug tool. Join them up when plug tool on plug. And hope they stay together when removing the gear from a newly inserted plug. 50/50. #1 is the worst plug.
Alan
Maybe a little crude Alan,
However works perfectly.
Nut weld to socket, then bolt weld to nut.
Old 11-10-2017, 09:17 AM
Alan L's Avatar
That nut/bolt thing must be the perfect length. Otherwise to tall to fit in some of the plug apertures and if shorter - can't get socket on. Thanks.
Brian - that is pretty much what I have right now. How are you pinning the extension - that is the issue I have - sometimes won't all come out as a unit.
Regards
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 11-10-2017, 08:43 PM
mark houghton's Avatar
Originally Posted by Norm K View Post
You do now, Mark, and one who wonders why you'd choose to not drop the engine, no less.
It takes about five minutes to remove the rear mounts and drop the engine enough to very easily reach the plugs from underneath. Reinstalling the mounts takes a bit more effort (lining everything up and holding the washers in place) but is usually accomplished within 10-15 minutes.
By the time you've "taken off all the crap that's in the way" I'm having a post-plug-change beer.
_
Hey Norm, by "drop" I was referring to "removing" the engine. That's what I thought the original post was talking about.
Yeah, dropping just a few inches makes a world of difference. Wish I had the proper Porsche tool instead of a menagerie of extensions, though.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 11-11-2017, 06:27 AM
Alan L's Avatar
Yes, I thought 'Drop' meant 'remove' also. But it is perfectly do-able without either.
I see Pelican have the Porsche tool listed - $105 approx..
By the time I pay airfreight etc it will turn out to be $200 by the time it gets here.
Alan
Old 11-11-2017, 10:55 AM
SBK930's Avatar
I found I was able to wind the bolt in until I got the best length. So some cylinders I used a socket and wrench, and mainly no. 1 used a rachet spanner.
With IC removed and air cond compressor moved to the left.
Old 11-11-2017, 09:39 PM
RarlyL8's Avatar
You don't need the factory tool. Pin the adapter to the socket like shown above and that is the only tool needed for all 6 cylinders. We have access to any tool we need and can make those we don't and this is what we use. Extremely simple and effective.
Old 11-12-2017, 04:28 AM
Alan L's Avatar
Brian - how do you pin the plug tool to the extension. I would imagine you are drilling in to hardened steel?
Alan
Old 11-12-2017, 10:23 AM
RarlyL8's Avatar
Not necessarily, you can use cheap tools that are easier to drill into sense the torque setting of a spark plug is so low.
Old 11-12-2017, 03:25 PM
