Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Raise your hand if you have ever changed plugs in a turbo with the engine in the car
My back is sore and my arms are scratched.
It takes a damned contortionist to do it, especially for #3.
I had a few parts off while troubleshooting an ignition problem, so I decided it was time for plugs. W-3-DP0 plugs are good for lots of miles and I am almost 69, so this will likely be the last time I do it.
1986 911 turbo - less than 30k miles
Old 11-07-2017, 03:16 PM
Jeff NJ's Avatar
I've done it, as well as leakdown and compression tests which requires pulling the plugs. I have no airbox, which helps, but it is a pita. The spark plug tool that comes in the toolset is genius and really helps.
1988 930 Venetian Blue
Old 11-07-2017, 03:42 PM
Crotchety Old Bastard
RarlyL8's Avatar
I did it yesterday. It's really not that bad, #1 can be a challenge. Remove the air box and intercooler to give yourself some room. I've done it with the intercooler in place and it's far worth the 5 minutes it takes to remove it.
Old 11-07-2017, 04:21 PM
mark houghton's Avatar
I don't know anybody who drops the engine to change plugs. Just gotta suck it up, take off all the crap that's in the way, and get to it with a lot of patience. Definitely a PIA no matter how you look at it.
For that matter, it's time for me to do it again. Good winter project, since I'm about to put her to bed anyway.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 11-07-2017, 06:29 PM
Strygaldwir's Avatar
I use a spark plug socket with an extension JB Welded to the socket. This lets me pull the socket from the plug without pulling the extension off. It make the whole process a LOT easier.
Keith
Old 11-07-2017, 06:34 PM
Kartoffelkopf
Spenny_b's Avatar
Remove the tinware and do it from underneath - when I was pulling plugs and diagnosing the woes I had a few years ago, I didn't find it much of an issue accessing any of them (I run twin plugs) but I did remove the slabs of tin separating top and bottom halves of the engine.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 11-08-2017, 03:03 AM
Agreed and that spark plug tool is the key!
Old 11-08-2017, 03:48 AM
kjchristopher's Avatar
Keith
I do the same, but with a socket that has a built-in swivel.
Old 11-08-2017, 05:53 AM
Turbo Powered Snow Blower
^^^ Yep. The factory tool is the best.
I had a socket get wedged in #1. Spent at least 15 min trying to get it out.
Derrick
Old 11-08-2017, 05:55 AM
Started yesterday afternoon, park plug tool is the best. Also changing fuel injectors and bleeding a little.
Bob
Old 11-08-2017, 06:09 AM
Norm K's Avatar
You do now, Mark, and one who wonders why you'd choose to not drop the engine, no less.
It takes about five minutes to remove the rear mounts and drop the engine enough to very easily reach the plugs from underneath. Reinstalling the mounts takes a bit more effort (lining everything up and holding the washers in place) but is usually accomplished within 10-15 minutes.
By the time you've "taken off all the crap that's in the way" I'm having a post-plug-change beer.
_
`66 912: Sold, `80 930: now resides in Poland, `84 Targa, now resides in The Netherlands, `75 911S: now resides in Northeast Germany, '83 Targa
Old 11-08-2017, 06:20 AM
gumba's Avatar
Yes, motor in. I wonder if a Porsche dealer charges for an engine out. What does the shop rate manual say.
Harold
'79 930/DP935
'68 VW Turbo Crewcab
Old 11-08-2017, 06:37 AM
_
In the time you spend lowering and raising the motor, I am done with the plugs.
Now, if you still have all of the original air injection/pump/hoses, that makes a difference, but I still did it without lowering the engine. Once I removed all of the air injection parts, it's a piece of cake. I always use the factory tool, and remove the IC.
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 11-08-2017, 07:20 AM
Im a pretty hack mechanic and dont recall having any issues at all the last time I did this. I think the key was finding just the right length extension IIRC.
Just changed the plugs in my subaru and that seemed much worse, though the pain is still fresh in my mind
07 Exige S
Old 11-08-2017, 07:45 AM
I "change" my plugs with the engine in but lowering the engine might be worth a try for comparison. I don't really change them I just clean, re-gap, tighten the top connector and re-install. Never seem to have a problem with them running many more miles.
Rahl
Old 11-08-2017, 09:47 AM
Porsche 935's Avatar
If you have issues with plugs, what do you do when you need to adjust the valves ?
3.3 ltr, stock compression, efi, twin turbo - no intercooler.
Old 11-08-2017, 09:58 AM
beancounter
jwasbury's Avatar
^ have you done the plugs on Der Phoenix yet? If that car still has 100% of the factory emissions crap that it carried when I shipped it to you, I think you might be looking at a partial drop to access plugs...with the air pump, EGR and all the associated plumbing, the intercooler and airbox are the least of your problems.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 11-08-2017, 10:49 AM
beancounter
jwasbury's Avatar
Did you replace the air injection parts after removal, or leave them in a box on the shelf?
Jacob
Old 11-08-2017, 10:50 AM
No, I did not reinstall or replace, I am sure that I tossed them.
Tim
1986 930
Old 11-08-2017, 11:25 AM
Alan L's Avatar
Can someone post a pic of their favourite plug tool? I don't know what the factory one looks like, but I am sure I can improve on what I do now - two different extension lengths on a regular plug tool. Join them up when plug tool on plug. And hope they stay together when removing the gear from a newly inserted plug. 50/50. #1 is the worst plug.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 11-08-2017, 04:27 PM
