Topocalma
Dimensioning of 'tasteful' rear spacers for Turbo Carrera
On my 77 Turbo Carrera the rear wheels do sit quite 'deep'. I have searched here and the web but did not find info on what would be a good spacing for moving the wheels out without it being 'too much'. It certainly do not want to risk touching the body under load.
Any thoughts / experiences?
1973 2,4T gemini blue
1977 3.0 Turbo slate grey
Old 11-14-2017, 12:10 PM
Administrator
Dmitry at Pelican Parts's Avatar
Take a look at the link below - it's a great guide on wheel fitment and spacing/offset. Hope this helps you a bit.
Wheel Fitment & Spacing Guide
Old 11-14-2017, 01:44 PM
stevie 77 930's Avatar
1977 Turbo had rear spacers
PET part number 930 331 611 04 superseded by this
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
2018 GTS
2017 BMW 340I M Sport Package
1977 930 (recently sold)
1976 911S , 1973 1/2 911T, 1972 911E (long gone)
Old 11-15-2017, 08:48 AM
Scottsdale Arizona USA
The original spacers were 28mm I think.
We have an extra set of these: $260 shipped
DRM Seriesฎ spacers bolt to the hub with existing wheel studs and special nuts (included).Wheel is bolted to new DRM wheel studs.H&R SUSPENSIONWheel Spacer Set - DRM 65mm (5x130 / 71.60mm) TRAK+ H&R - List: $289.95
EP-West // Automotive Part Connectors & MODE : Motorsport Design
1 (844) URO-PART // day@europartswest.com // mode@europartswest.com
Old 11-15-2017, 09:08 AM
DSM DSM is offline
DSM's Avatar
My 77 Turbo Carrera came with spacers. Pretty sure they are factory. Could give you the part numbers for spacers(will advise thickness) and stock rear Fuchs if you would like? Note: Rear spacers were removed to fit 10” wide BBS E50s.
Old 11-15-2017, 09:39 AM
Topocalma
That would be great - I want to add 15 - 20mm... advice on thikness would be much appreciated!
Old 11-18-2017, 12:13 PM
DSM DSM is offline
DSM's Avatar
Rear Spacer: 930.331.611.04 (28mm)
Rear Wheel: 911.361.020 45 (16x8)
Rear Tire: 245/50 R16
Old 11-19-2017, 03:51 PM
Topocalma
Thanks! this is super helpful.
DSM, I take it in your last post you show the setup factory spacers (28mm) and rims (16 x 8) but 245/50 R16 instead of the factory 225/50 R16. Looks like the tire aligns perfectly with the flares in this setup and easy to do....!
Old 01-04-2018, 12:18 PM
Adapters
With the original 9x16 rear Fuchs the 245-45R16 tires looked too far 'tucked in' so I exchanged the stock 28mm spacers for 43mm adapters. No need to change the studs. The look is just right, and no tire contact.
Old 01-12-2018, 09:32 AM
T77911S's Avatar
its only too much if they rub.
one thing to look at is are both sides the same. IE do the wheels sit in too much the same amount on both sides. mine did not. I needed an additional 1 inch on one side and about 1.5-2inches on the other to make the wheels look the same in the fenders.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 01-12-2018, 10:29 AM
