Turbokraft Oil Feed doesn't fit 3.2 Carrera
Hi,
Dont know if anyone here has some knowledge on this. Engine is a 3.2 Carrera from 1987.
I purchased the oil feed kit that goes off of your oil pressure sensor from TurboKraft.
size is are different.
Any solutions? Ive emailed Turbokraft already. Maybe I can get a refund. or find an adapter.
Thanks.
Old 11-24-2017, 11:23 AM
scottrx7tt's Avatar
You have to buy the 930 block adapter. I went through the same thing when i did my turbo conversion. It shows the adapter in the turbokraft website with the banjo bold, BUT it isnt inluded.
https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=0ahUKEwiPjYePqdjXAhWxk-AKHZgADTcQjRwIBw&url=https%3A%2F%2Fparts.turbokraft.com%2Fproducts% 2Fturbocharger-oil-feed-check-valve&psig=AOvVaw0gi5N-Fnec1FO2YnWA5bRm&ust=1511651027091204
1979 911SC widebody conversion. 3.1 engine, 3.2 liter heads, carrera intake, Microsquirt V3 ECU, K27 7200 High flow turbo, Tial F41 wastegate, Ford EDIS. .7 bar. 402hp 360tq
Old 11-24-2017, 03:05 PM
TurboKraft's Avatar
Hi Jeffrey,
Sorry, looks like your email came in while the office was closed for the Thanksgiving holiday.
Yes, the oil check valve kit is designed for the 911 Turbo engine, which has an M18/M14 adapter block threaded into the engine case.
Your non-turbo engine hasn't got this, its adapter is M18/M10.
We may have an adapter in stock at the shop, I will check on Monday.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 11-25-2017, 07:26 PM
