Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Capt Bob
Capt Bob's Avatar
930 4 speed - synthetic to swepco
Is there any issue changing the gear oil in a 930 four speed gearbox from synthetic back to Swepco 201 manual transmission lube 80W-90?
Are there pros and cons when comparing synthetic to 80-90? My 1982 930 has 88,000 miles on it.
Old 11-27-2017, 03:52 AM
T77911S's Avatar
I don't think the syncros work as well with syn, its "too slippery".
do you have LSD?\
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 11-27-2017, 06:57 AM
Capt Bob
Capt Bob's Avatar
Yes, LSD.
I'm going to drain all the synthetic out of the gear box and let it drip out for a while then top off with the Swepco 201.
Just not sure if there is any issue with mixing the residual synthetic that remains on the gears with the fresh Swepco when topped off.
Old 11-27-2017, 07:28 AM
mark houghton's Avatar
Synthetic too slippery from what I've heard as well. Personally, I wouldn't worry about a very low level of mixing the two together after a good thorough drain of the synthetic. If you're still concerned, add the Swepco - run it for a short spell - then shell out the $$bucks$$ and drain/ replace.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 11-27-2017, 06:52 PM
gearhead
Dont worry about it.
1974 911 Restorod
1974 914 Bumble Bee
1975 911S Tom's Targa
2008 Cayman S Mule
Old 11-27-2017, 07:20 PM
Capt Bob
Capt Bob's Avatar
Ok - synthetic out Swepco in...running well. Thanks!
Old 12-01-2017, 08:18 AM
What is the pelican-brain-trust recommended change interval for 930 tranny?
Old 12-02-2017, 04:51 AM
This stuff is really good too.
Kendall 80W-90 Gear Oil With Limited-Slip LSD Additive
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
Old 12-02-2017, 11:23 AM
gearhead
I go 15k mi or every 3 years, whichever comes first.
1974 911 Restorod
1974 914 Bumble Bee
2008 Cayman S Mule
Old 12-02-2017, 11:52 AM
If it helps you.
the gear oil recommended by Porsche Classic is this: Fuchs Titan Supergear HXP 75W-90, SYN gear oil GL5
Greeting Dominik
Old 12-02-2017, 07:33 PM
I suggest that you read a lot more about Swepco. BA used to recc it and it seemed to help various Porsche transaxles shift smoother... Only it turned out that it is too slick and people tend to shift too fast and ...yes.. wear out their sycros a lot faster. I ran it for a while in a 930 but swapped it out as more information came out. it's a good product but not so compatable with Porsche sycros. From G50 on it may be great.
Old 12-11-2017, 01:04 PM
Bully's Avatar
Royal Purple
Had a buddy tell me that he switched to Royal Purple and had a much easier time 2nd to 3rd and vice versa.
Anyone else hear this?
Would be handy, as my synchros are tired.
Old 12-12-2017, 11:00 AM
gearhead
When the synchros get worn, they struggle to make enough friction to change the speed of the shift sleeve during engagement. Moving over to a more slippery oil like Royal Purple will likely make the shifting worse, not better.
1974 911 Restorod
1974 914 Bumble Bee
2008 Cayman S Mule
Old 12-12-2017, 01:41 PM
Capt Bob
Capt Bob's Avatar
The swepco seems to have helped my situation shifting into 3rd gear...got to go nice and slow and its nice and smooth.
Old 12-14-2017, 03:49 AM
beancounter
jwasbury's Avatar
I ran the Motul supercalifragilisticexpialidocious full synth spendy gear lube in my 930 box and it was great...noticeably better than before.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 12-14-2017, 06:01 AM
'76 911S 3.0's Avatar
Pelican Parts - European Automotive Parts and Accessories - Porsche BMW Mercedes Volkswagen Audi Saab Volvo MINI
This stuff made a world of difference for me
-Jayson
1976 911S Signature Edition
3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, Tial 44mm, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 12-14-2017, 08:52 AM
TheSt|G's Avatar
Royal purple is a known failure fluid in the BMW world, I wouldn't let it anywhere near my car.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 12-16-2017, 06:05 AM
VZ935's Avatar
Send a message via AIM to VZ935
Swepco, swear by it
A bunch of old race cars
Old 12-17-2017, 11:59 AM
