Capt Bob
Capt Bob's Avatar
Oil cooler fan test switch
Got a question - How do I test the oil cooler fan switch on my 1982 930? I checked the harness and I can run the fan by jumping power across the solenoid up by the forward fuse panel and the fan runs fine. The temp switch on the left side chain cover and is in a real bad area with intake pipe to the turbo.
'm not sure if it works and or what temp it is set to turn on the fan.
Old 12-05-2017, 07:38 AM
stevie 77 930's Avatar
That switch in your picture is the thermo-time switch that controls cold starting through the cold start valve. (not an oil cooler fan) The oiler cooler fan can be switched via a switch or thermostat switch located on the oil cooler.
Temp Switch Sender Kit for Oil Cooler Fan 911 Carrera - 930 turbo By Patrick Motorsports Porsche & Mid Engine Performance Specialists
2018 GTS
2017 BMW 340I M Sport Package
1977 930 (recently sold)
1976 911S , 1973 1/2 911T, 1972 911E (long gone)
Old 12-05-2017, 09:21 AM
Capt Bob
Capt Bob's Avatar
Ok thanks for the info. I will check the oil cooler for the temp switch. Thanks!
Old 12-05-2017, 05:34 PM
Some people replace the original oil cooler fan thermostat switch with a similar one for BMW's that turns the fan on at a lower temperature. It fits the same threads.
You can also hook up a manual rocker or toggle switch to turn it on anytime.
Old 12-05-2017, 05:52 PM
Correct me if in error, I thought for USA cars oil cooler was not equipped w/ fan until 87? I see you have an 82 meaning Euro orig. I believe fan sensor is supposed to trip at around 244F. I did the manual rocker switch on my 86.
Old 12-05-2017, 07:33 PM
Capt Bob
Capt Bob's Avatar
Yes my 930 is a Euro but has been updated over the years. 244F seems high to me and especially being in Florida I would prefer to see the temps 20 degrees lower than that. Maybe a manual rocker for me rather than hoping the temp switch works when I'm stuck in traffic somewhere around Tampa.
Old 12-06-2017, 09:40 AM
T77911S's Avatar
what does you oil temp run at now?
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 12-06-2017, 11:00 AM
Gasoline User
1974carrera's Avatar
On my '77 I wired the headlight washer switch on the dash into the circuit so I can also turn on the oil cooler fan manually when I want instead of waiting for it to first get hot enough for the temp switch to activate the fan. I never use the headlight washers anyway and it leaves a stock appearance.
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2013 Cayenne GTS Schwarz
2014 911 GT3 Rhodium Silber
Old 12-06-2017, 02:31 PM
Brando
quattrorunner's Avatar
I did that too and in vegas I left it on most the time. You should use a relay as it over heated my switch.
Turbo powa!
1977 911s. it's cool
Old 12-06-2017, 08:28 PM
Gasoline User
Good suggestion about the relay. IMO any cooler fan should use a relay regardless of whether or not a manual switch is used.
Bob V
Old 12-07-2017, 05:56 AM
Capt Bob
Capt Bob's Avatar
During the summer in Tampa Florida the engine temps would creep up above 250 degrees. Also, I'm running synthetic oil in the engine as well. Now with the weather cooling off in Florida the car typically runs around 220 or so. Additionally, I recently installed the air scoop (see photo) that helps increase the air flow across the oil cooler and of course helps dissipate the heat. I'm planning on fixing the oil cooler fan switch issue this weekend and I should then be prepared for next summer.
Old 12-08-2017, 03:18 AM
