New 3.45L Build
A while back I decided to build up another motor while enjoying the one I have. So, I ended up buying a spare case from IndyPR and then I happened to find a billet 76.4 crank. After discussing this with Turbokraft, I ended up shipping a bunch of parts that I accumulated and had them add their usual offerings. While I'm not really chasing HP right now....Who knows what I'll want later. So, this was build up with the good stuff they usually use and should handle whatever I come up with in the future. It is now sitting in my garage waiting to be finished. A big thanks to Chris and his team. I can't wait!
-Todd
1987 911 Turbo, Marine Blue, GT35R, BB Headers, Tial, Andial IC
Old 12-08-2017, 05:44 PM
lite75's Avatar
That crank is a beauty, I'd have a hard time hiding it in the case!
75 930, 76 930, 83 SC EFI turbo
Old 12-08-2017, 07:51 PM
Thanks. There are quite a few parts that look great but will never (hopefully) see the light of day again.
Shuffle pin & boattailed case
ARP
Coated GT3 bearings
Pauter rods
CP Carrillo 98mm
LN cylinders
Need to track down some more parts...
-Todd
Old 12-10-2017, 03:42 PM
Life seems to be getting in the way a lot lately. But, things are still moving.
I finished the new engine harness without all the extra wires. Knock sensors now have shielded wires, powdercoating is done and Pacific Oil Coolers blessed my cooler.
I now need to search for another throttle bellcrank and waiting for the air port plugs before adding the exhaust/Turbo stuff.
In a moment of weakness, I ordered a TK billet-tank IC, so, I can't wait to put it on!
-Todd
Old 02-14-2018, 09:46 AM
kevinbodman930's Avatar
Is that break in wine on your work bench?Motor looks really good.
Old 02-14-2018, 10:32 AM
Looks like another EFI conversion in the works. What type/brand are the COP's?
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 02-14-2018, 02:21 PM
'76 911S 3.0's Avatar
Those look like Toyota/Denso COPs
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 02-14-2018, 04:28 PM
Yes, those are Toyota/Denso.
And...that is a beer bottle. No wine here.
-Todd
Old 02-14-2018, 04:58 PM
I'm jealous! Spoke w/Chris about converting my car to EFI about a year ago and couldn't swallow the #! Here's to next year...
Cheers,
Patrick
'78 930 #441
'87 951
Old 02-15-2018, 06:02 PM
puddy's Avatar
So jealous, looks fantastic!
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 02-16-2018, 04:23 AM
How is that new intercooler?
I can't wa it to see it on your motor.
Old 02-18-2018, 10:16 AM
TurboKraft's Avatar
Thanks, Todd! Looking forward to seeing this all come together.
Billet intercooler tank is in process now, slowly turning almost 80# of aluminum slab into <1.5lb of end tank. :-)
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 02-19-2018, 01:43 PM
Was going to mount the air pulley housing to start the mods for a cam sensor and the housing won't seat because it is hitting the lower #3 COP.
Before I put that in the mill and make it fit, I was hoping someone who has experienced this before would tell me how they solved this.....
-Todd
Old 02-20-2018, 04:09 PM
TurboKraft's Avatar
Notch the housing with a die grinder for COP clearance.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 02-20-2018, 06:16 PM
Thanks Chris! Just wanted to make sure before removing metal.
-Todd
Old 02-20-2018, 06:27 PM
How is that intercooler looking on that beautiful motor?
Old 03-11-2018, 04:51 PM
No IC yet, but can't wait to see how it all fits together. It's starting to become more of a puzzle. I can't mount tins until I get the temp sensor for cyl3 and I can't run wires or hoses until I get all the throttle parts to make sure I don't use the space they need. So, I have been working on the rear tin that needed some work and now it needs to be powdercoated. I also got the air pump housing modified to clear the COP, set the cam sensor position and crank sensor installed. I should be able to get moving once again soon.
-Todd
Old 03-12-2018, 04:26 AM
Looks really good.What ecu do you think you will be running?
Old 03-12-2018, 11:48 AM
Why use stock rails when you can spend a bunch of time and $$ making them!
??? I have a buddy that has some unused ID1000 injectors. Provided the length and diameters are correct, would they be a good fit for this build???
-Todd
Old 03-15-2018, 10:52 AM
TurboKraft's Avatar
Nice!
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 03-15-2018, 11:28 AM
