-   -   '79 930 dies while driving... can instantly restart (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/980483-79-930-dies-while-driving-can-instantly-restart.html)
Discseven 12-12-2017 04:50 AM
Driving and engine quits... tach drops to nothing... think oil & gen light came on but not betting my life on it now---was on highway busy thinking about ops if car did not start. Push clutch in and key the ignition and it started right away. Happened twice during 1.5 hour drive. Same immediate key restart (while rolling) both times. ???
4,000 miles ago... new: alt, ig wires, plugs, coil, dist cap & rotor, forward fuel pump, ground strap.
T77911S 12-12-2017 06:00 AM
CD and coil are something to consider. BUT, usually when they do this it is due to heat and the car DOES NOT start until they cool off, just something to keep in the back of your mind.
there is a "delayed action" relay that powers the CD unit. this is what keeps the CD on and keeps the engine running after you turn it off. if you can solder I would consider pulling it out and resoldering the joints.
same thing with the over boost relay. try resoldering the joints,
fuel pump relays. could replace them.
I would remove the connector on the rear of the AFM so the pumps will run with the engine off. then when it quits don't touch anything. check the see if the pumps are running.
check the over boost sensor and wiring. try wiggling the wire with it running.
I don't know if power for the CD goes thru the connector on the relay panel in the engine bay or the one at the firewall. probably the relay panel. pull that connector and check the pins. make sure they are tight and clean.
could also be the green wire from the dist to the CD unit. wiggle it with the engine running.
check the sockets on all the relays mentioned. make sure they fit properly.
problems like this suck because you cant fix it if it aint broke and if one of these does fix you may only know because you wont break down again. good thing is there really is not much that will do this.
gsxrken 12-12-2017 06:53 AM
I don’t know if the 79s had the Speed relay under the drivers seat like my 86, but I had your exact problem intermittently. One day I hit a huge bump and the car died- pulled the plug off the back of the fuel distributor and with key on had no fuel pumps running... left key on and went wiggling and when my hand touched that relay the pumps kicked on. I cleaned and reseated that and have not had the issue again in years.
T77911S 12-12-2017 07:17 AM
nothing under the seat.
Discseven 12-12-2017 09:39 AM
Input is appreciated guys.
Nice hit list T77... I can solder... thanks! http://forums.pelicanparts.com/support/smileys/wat6.gif
Let you know outcome.
stevie 77 930 12-12-2017 11:28 AM
over boost sensor is easy and cheap to replace. Start there....
Ken911 12-12-2017 11:54 AM
Sounds like the green wire to me. mine was intermittant and i chased it for a couple years until it was bad enough for me to actually find it. One time it died in traffic and decided to start the moment the tow truck arrived.
TDH888 12-12-2017 03:15 PM
Hi guys ,
I hope this question wont derail the thread , Ive always read about the green wire and always wondered were can this be found in the car . Is it from the distributor ? Connected to were ?
Thanks in advance ,
Tdh888
Discseven 12-12-2017 03:24 PM
Was at ParkHaus today to get Bpads... and looked at pricing for both of those sensors while there. OB sensor is on menu. Gotta sort out totality of what was done 4k miles ago ('15) to narrow diagnosis approach.
I know that tow truck trick---works well sometimes. My distrib to CDI wire 4k ago (below.) Is coax. Forgot exact symtoms--- think it was run sometimes and not at other times... and cut off while running. Don't think it started right away. New green wire is installed. Junctions will be checked.
Old wire junction... clearly on last legs.
http://forums.pelicanparts.com/uploa...1513120941.JPG
Rawknees'Turbo 12-12-2017 03:35 PM
Originally Posted by TDH888 (Post 9846347)
Hi guys ,
Thanks in advance ,
Tdh888
The wire is connected on one end to the distributor, passes through a wire sleeve bundle, and is connected at the other end to the CDI . . . the inner wire carries the signal from the CDI, and the outer, braided/shielding wire is connected to the CDI common ground terminal.
'76 911S 3.0 12-12-2017 03:58 PM
The tach dropping to nothing immediately indicates something with the ignition/CDI to me
Discseven 12-12-2017 04:37 PM
Rawknuckles illustrated...
http://forums.pelicanparts.com/uploa...1513125252.JPG
Condition of green wire junction at distrib is not easily noticed because entry location being at backside of distrib.
If correct... that narrows things down. Am not sure how to test CDI for rare failure.
Rawknees'Turbo 12-12-2017 04:43 PM
KinkyKarl, I thought you were selling that bisch, bisch?!?! :)
TDH888 12-12-2017 04:55 PM
Thanks you ,
tdh888
TDH888 12-12-2017 04:58 PM
Thanks guys,
tdh888
Discseven 12-13-2017 01:48 AM
RonObisch, yup... still sellin. Hope all's more than well with ya Norflander!) :)
Discseven 12-13-2017 03:54 PM
Pulled fuel tank to recoat. Be a few days messing with this then will dive into diagnosing electrical issue. Will update thread with whatever's found.
http://forums.pelicanparts.com/uploa...1513209329.JPG
Bare metal. Will use Wurth Stone Guard Gray.
RarlyL8 12-13-2017 05:30 PM
This is the beginning of an electrical failure. Isolate and check the parts that can kill power to the ignition. This will include all relays, all fuse fixtures, all associated wiring, and every component of the ignition system. Checking dead paths for resistance can locate a corroded connection or damaged wire, testing strength of voltage on live paths can detect faulty components. Blindly replacing parts gives no assurance that an intermittent problem is fixed. I just went through the same scenario with my 930 after replacing most of the ignition system as normal maintenance. Pretty aggravating to have it leave you stranded after a full tune-up.
T77911S 12-14-2017 05:41 AM
hey brian, you said my WUR has separate adjustable boost and WCP, it does not, when are you going to do something about it. ignoring my PM's is not a solution?
RarlyL8 12-14-2017 10:12 AM
I'm not ignoring anything, send me an EMAIL with your contact info like I asked and we'll get it taken care of. You also need to send it back so we can see what's going on.
Now back to the thread at hand...
Checking everything that can kill the ignition also includes the ignition switch and associated wiring.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
